• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    Half view accidently saved
    112 Views, 3 Replies
    02-22-2013 06:59 AM
    This is now happened on two different assemblies. I was using the half view function on an assembly to view an interior part, then went to another page to edit a part. When I came back to the assembly, the half view is saved and I cannot save it as whole again. When I save it, it will reappear with the half view cut out of it.
    How do i correct this. It is getting aggravating.
    Please use plain text.
    cbenner
    Re: Half view accidently saved
    02-22-2013 07:30 AM in reply to: chance1080p
    When you did this, did you happen to be in an open View Rep?  If so, your half view probaly got saved to that view rep.  Try opening the Master view rep, or creating a new one and see what happens.
    ChrisB
    Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
    *Pro
    02-22-2013 07:52 AM in reply to: chance1080p
    How about just using the End Section View tool (right below the Half Section View tool)?
    Sam B
    Inventor 2012 Certified Professional
    Please click "Accept as Solution" if this response answers your question.
    Inventor Professional 2013 SP1.1 Update 1
    Windows XP Pro 32-bit, SP3
    HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
    SpaceExplorer/SpaceNavigator NB, driver 3.7.18
    still waiting for a foreshortened radius dimensioning tool in Drawing Manager
    Member
    02-22-2013 08:03 AM in reply to: sbixler
    We setup a custom User Command box and only had the half view and just clicked done or cancel when finished to retreat back to complete solid. Just added the end sectioon view to my box and got it back working.
    I'll tell everybody to add it.
