• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    HELP Loft is showing difficult to follow
    53 Views, 1 Replies
    10-09-2012 04:18 AM
    Hi
    I am following the U-Tube exercise called "Emergency Light (Cabinet) volume 1".
    I am at time stamp 1 hour 26 minutes, exactly.
    In the video they use a Loft command in order to cut a shape out of two sketches numbered 10 & 11.
    I have been copying exactly and am having difficulty at this stage of the model.
    Is there any reason why I am managing to use the Loft command earlier perfectly but not at this point.
    I would appreciate any help from anyone.
    Kind regards
    A CAD Student.
    http://www.youtube.com/watch?v=cBu3UjXG_cM
    This is the URL to see what should be happening. The Loft command works here, but when I try it i wont.
    Is there anyone that can and will help me please I am in need of help please.
    Please use plain text.
    Re: HELP Loft is showing difficult to follow
    10-09-2012 04:23 AM in reply to: Forumhelp2012
    Why this repost http://forums.autodesk.com/t5/Autodesk-Inventor/Loft-command-not-working-for-a-cut-Any-suggestions/t...
    I don't see where you made the changes I suggested in my first response.
    It works here fine when I make these suggested changes.
