• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    deonlemmer
    Going from a flat pattern to a pressed part
    101 Views, 4 Replies
    06-21-2012 07:52 AM
    I have the flat pattern of my part, and the press tool. Is there a way to form the flat pattern to the shape of the press tool?
    Please use plain text.
    *Expert Elite*
    Re: Going from a flat pattern to a pressed part
    06-21-2012 08:58 AM in reply to: deonlemmer
    Attach the files here.
    *Expert Elite*
    06-21-2012 09:12 AM in reply to: JDMather
    Seems like such a backasswards process..
    If I understand you right, I would place the die and the flat pattern into an assembly file. Constrain the die/flat in the right place then edit the flat pattern in the assembly and create a sketch and project the die edges onto the flat.. Then fold the flat up using those projected lines..
    How is it you have a flat pattern and have build a die but don't have the as formed part..How was the die built? How were the flat dimensions defined?
    Please click "Accept as Solution" if this response answers your question.
    2012 Product Design Suite Ultimate
    Windows 7 64 bit
    90G OCZ SATA 3 SSD (My SSD is faster than your HDD)
    Core I7 920 processor, ATI HD6970 graphics card, 12G Corsair RAM
    New Member
    deonlemmer
    06-21-2012 10:59 PM in reply to: mcgyvr
    I thought about it and decided that it is not worth the trouble to try and get to the pressed part. Will do some trail and error in the workshop. Thanks for the reply.
    *Expert Elite*
    06-22-2012 04:31 AM in reply to: deonlemmer
    Could be trivially easy.
    Attach your files here.
