• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    Generating an Elbow on a metal part drawing
    277 Views, 4 Replies
    10-17-2012 10:33 PM
    I would like to ask , how to create the elbow part of a metal type  ( actually a  J-shape Bolt  Threaded material)  .
    I had finished  the  straight part  by  simply revolving my required profile. then i was to  draw the  elbow part but "sweep" doesnt  work  out
    Please use plain text.
    *Pro
    Re: Generating an Elbow on a metal part drawing
    10-18-2012 04:34 AM in reply to: krcastillo
    Inventor version?  Post the file here.
    In what way does Sweep not work out?  Have you tried using the Bend Part tool?
    *Expert Elite*
    10-18-2012 10:26 AM in reply to: sbixler
    If all you want is a "j bolt" you need 2 sketches.. 1 is just a "J" shaped single line sketch.. Then the other sketch is just a circle starting on a plane perpendicular to the first sketch start or end point. Then sweep and voila a "J"
    see attached (done with INV 2012)
    Please click "Accept as Solution" if this response answers your question.
    2012 Product Design Suite Ultimate
    Windows 7 64 bit
    90G OCZ SATA 3 SSD (My SSD is faster than your HDD)
    Core I7 920 processor, ATI HD6970 graphics card, 12G Corsair RAM
    hagiographa
    10-18-2012 08:46 PM in reply to: mcgyvr
    Is this what you want?
    I'm not sure how you'll get the nut past the bend?!
    Valued Contributor
    PhilSaw
    10-19-2012 01:55 AM in reply to: hagiographa
     A Google search on "J Bolts" shows the thread on the straight part only - so no, that isn't what the OP is after.
    http://www.google.co.uk/imgres?q=J+BOLT&um=1&hl=en&safe=active&sa=N&biw=1053&bih=494&tbm=isch&tbnid=...
    Autodesk Inventor Professional 2012
    Windows 7 Professional, 64-bit (Service Pack 1)
    Intel(R) Core(TM i7-2600 CPU, Quadro 2000 graphics card, 8G RAM
