Autodesk Inventor
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Generated gears are not visible in assembly
Options
- Highlight
- Email to a Friend
100 Views, 1 Replies
01-11-2013 03:04 PM
I'm new to Inventor so it might be something obvious, but I've already spent a couple of hours trying to figure it out, and searching doesn't seem to yield anything helpful.
I'm creating a pair of spur gears using Gear Generator. I can see the preview of the gears geometry when I'm in the generator dialog. However, when I click OK and a new part is generated, I can't see any generated geometry in my assembly. The part seems to be empty.
I'd appreciate any advice.
Re: Generated gears are not visible in assembly
Options
- Highlight
- Email to a Friend
01-12-2013 03:48 PM in reply to:
ilobanov
It turned out that two cylindrical faces used to construct the gears were not quite in the same plane, so that generated gears wouldn't be touching each other. I added assembly constraint and it now works fine.
