• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    Generated gears are not visible in assembly
    96 Views, 1 Replies
    01-11-2013 03:04 PM
    I'm new to Inventor so it might be something obvious, but I've already spent a couple of hours trying to figure it out, and searching doesn't seem to yield anything helpful.
    I'm creating a pair of spur gears using Gear Generator. I can see the preview of the gears geometry when I'm in the generator dialog. However, when I click OK and a new part is generated, I can't see any generated geometry in my assembly. The part seems to be empty.
    I'd appreciate any advice.
    Please use plain text.
    New Member
    Re: Generated gears are not visible in assembly
    01-12-2013 03:48 PM in reply to: ilobanov
    It turned out that two cylindrical faces used to construct the gears were not quite in the same plane, so that generated gears wouldn't be touching each other. I added assembly constraint and it now works fine.
