• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    Frame genrator en Notching problem
    211 Views, 1 Replies
    09-08-2010 12:50 PM
    I made a simple frame to use in a bigger part. Now I did this with frame generator using HE-B profiles 400. Now the small vertical beams needs to be notched for welding. But hen I use the Inventor command for his, it all make beauty full radius on the end... But this is not how we do it in the fabric. I need a chamfer at all hose beam ends like 35x45degrees.. How do I do this, because also the chamfer command would not work, since it does not allow me to select the edges where I want my chamfer?
    *Pro
    Re: Frame genrator en Notching problem
    09-08-2010 01:53 PM in reply to: buurjongenshon
    Probably much easier to insert a note in your Preparations or leader on the drawing.
    IV2013 Ultimate / Autodesk Sim 2013
    Win7-64
    EVGA X58 - Classified, iCore7 990 24Gb Trip-Channel
    480Gb (2 x 240Gb SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-590 Classified - 301.42
    SpacePilot 3.15.3 / 6.15.3 / 3.12
