• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    Cool_Breeze_Jr
    Frame generator
    172 Views, 4 Replies
    10-30-2012 01:19 PM
    My skeleton has lost translation with my frame generator and has offset the sketch. I have tried "Edit with Frame Generator" but the peices seem to stay in place.
    Chris Biggs
    Engineer/CADD Services
    New Horizons RV Corp.
    2401 Lacey Drive
    Junction City, KS 66441
    Dell XPS 8300
    Intel(R) Core(TM) i7-2600 CPU@3.40GHz
    16GB RAM
    Win 7 64
    Yeah, it kicks booty!
    Please use plain text.
    Product Support
    Re: Frame generator
    10-31-2012 04:03 PM in reply to: Cool_Breeze_Jr
    You ae more than likely dealing with a corrupted file. Not sure if you have a backup of the assembly and not sure if you can do a replace component on it either as I never tried this. You can try using dethe "task schedular"  and run the file tion utility, choose option "Total Rebuild" and "Compact Model History" and let this run on the assembly file and all files for the project. Try opening the assembly then.
    Don
    Valued Contributor
    Cool_Breeze_Jr
    Re: Frame generator
    11-01-2012 05:07 AM in reply to: 4donwan4
    Don,
    Thanks for the reply, however I am not using any type of vault so these options are not possible. Being that only 2 of us work here we just copy what we need to modify.
    Chris Biggs
    2401 Lacey Drive
    Dell XPS 8300
    16GB RAM
    Win 7 64
    cbenner
    Re: Frame generator
    11-01-2012 06:18 AM in reply to: Cool_Breeze_Jr
    Have you tried a "Rebuild All" in Inventor?  Sometimes this works....
    ChrisB
    Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
    Valued Contributor
    Cool_Breeze_Jr
    Re: Frame generator
    11-01-2012 06:48 AM in reply to: cbenner
    I tried that with no results. I think the file is corrupt. Thanks for the suggestion though.
    Chris Biggs
    2401 Lacey Drive
    Dell XPS 8300
    16GB RAM
    Win 7 64
