• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Frame - Notch with offset
    189 Views, 3 Replies
    10-05-2012 12:58 PM
    Hey again guys,
    Another question using IV 2013  and Frames.
    When i get some frames and need to use the feature NOTCH, is there a way to put one offset on it ? like we can do using MITER ?
    The solution we've found here is in every member that we use NOTCH, we enter in the frame part and then use the feature THICKEN/OFFSET, this wey i can get the standard offset of 3mm that we use here for welding.
    Or, if there is other easy way instead of NOTCH, to make one frame get to other with offset.
    The image below shows what i mean, i need to get this off set in the frames on Z AXIS.
    Thanks very much!
    Túlio Barata
    IV 2013
    Please use plain text.
    *Expert Elite*
    PaulMunford
    Re: Frame - Notch with offset
    10-05-2012 02:01 PM in reply to: tuliobarata
    Try this:
    http://forums.autodesk.com/t5/Autodesk-Inventor/frame-generator-notch/td-p/2193144
    The CAD Setter Out Blog
    @CadSetterOut
    Please use the Mark Solutions! Accept as Solution or Give Kudos! Kudos functions - Thank you!
    10-08-2012 01:56 PM in reply to: PaulMunford
    Thanks man!
    Well, a good way to solve it with that answer, better than mine when i get many and many frames...
    Túlio Barata
    IV 2013
    *Expert Elite*
    PaulMunford
    11-01-2012 12:39 AM in reply to: tuliobarata
    No Problem :smileyhappy:
    @CadSetterOut
