• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    Frame Generator Sketch and Plane Visibility
    77 Views, 1 Replies
    01-09-2013 08:36 AM
    I added another extrusion profile to my structural shapes library, using the same method as the others a few years ago.  It works, but the new extrusion now shows up with its profile sketch, start and end planes, and driven dimension visible.  The old stuff doesn't (like I would expect).  I have all planes in the published part turned off, not marked for export, etc., just like in the old ones.  What's going on here?  How do I turn this off?  Inventor 2012 SP2.
    When I open the extrusion separately, the work features to not display.  But, the it's also shown as the "default" color not as material.  Why does it default to "default" not "as material" like everything else?
    Please use plain text.
    Active Contributor
    Re: Frame Generator Sketch and Plane Visibility
    01-09-2013 08:54 AM in reply to: smjanows
    Nevermind.  My parts have a defualt as well as master design view.  The old ones only had a master.  I deleted the design view, turn everything off in the master, and viola!
