• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    Frame Generator Problem
    899 Views, 11 Replies
    10-16-2012 04:54 PM
    When I try to open the Frame Generator Feature in Autodesk Inventor 2013, the dialog box does not appear and I am unable to create or edit frame members. This was not an issue in the 2012 version that I had installed. Does anyone have an idea what the problem is? Thanks!
    -Tyler
    Please use plain text.
    Distinguished Contributor
    Re: Frame Generator Problem
    10-16-2012 07:29 PM in reply to: tyler.chidester
    Tyler,
    I'm not up to 2013 yet, but in 2012 the shapes are edited and created in the sketch environment then enabled for FG use via the Structural Shapes tool, right?
    If you're saying the dialoge box is offscreen then this post has some good suggestions...
    http://forums.autodesk.com/t5/Autodesk-Inventor/dual-monitor-issues/m-p/2646647/highlight/true#M3688...
    Hope this helps,
    Member
    10-27-2012 12:24 PM in reply to: tyler.chidester
    Thank you for your response. I dont think it is a problem on the dialog box appearing off screen. I tried several tricks and I just do not think to dialoge box is showing up at all. Any more suggestions? Thanks.
    Tyler
    *Expert Elite*
    10-27-2012 12:57 PM in reply to: tyler.chidester
    Open the Tutorial Files > analyze_frame.iam
    Right click Edit the Frame0001
    Right click Edit with Frame Generator the  first frame member.
    What happens?
    Member
    10-27-2012 01:40 PM in reply to: JDMather
    Where do you find that tutorial file?
    *Expert Elite*
    10-27-2012 02:15 PM in reply to: tyler.chidester
    http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=16463987#
    Valued Contributor
    10-27-2012 02:29 PM in reply to: JDMather
    JDMather u help to all of the people? or any one u want?
    Behzad Meskini
    freedom for Iran
    Member
    10-27-2012 03:59 PM in reply to: JDMather
    JDMather:
    Thank you for your response. I tried what you said and have the same issue. Attached is a screenshot of my problem. as you can see there is no dialoge box in sight. Do you have any idea what the problem could be? Thanks
    *Expert Elite*
    10-27-2012 06:43 PM in reply to: tyler.chidester
    Your screen capture would have been a little more informative if you and first clicked on the Design tab.
    Sure looks like you are in Frame Generator edit mode but the dialog box is somewhere off-screen.
    Are you or have you ever used dual monitors with this box?
    *Expert Elite*
    10-27-2012 06:51 PM in reply to: bms953
    I answer the easy questions if I think I know the answer.
    About the only things I know are - "Sketch1 isn't constrained" and "an iam without ipt files is useless".  :smileytongue:
    If you stay here a while you will see that I have copied those two responses here around 19,000 times.
