Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Frame Generator Problem
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
When I try to open the Frame Generator Feature in Autodesk Inventor 2013, the dialog box does not appear and I am unable to create or edit frame members. This was not an issue in the 2012 version that I had installed. Does anyone have an idea what the problem is? Thanks!
-Tyler
Re: Frame Generator Problem
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Tyler,
I'm not up to 2013 yet, but in 2012 the shapes are edited and created in the sketch environment then enabled for FG use via the Structural Shapes tool, right?
If you're saying the dialoge box is offscreen then this post has some good suggestions...
Hope this helps,
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thank you for your response. I dont think it is a problem on the dialog box appearing off screen. I tried several tricks and I just do not think to dialoge box is showing up at all. Any more suggestions? Thanks.
Tyler
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Open the Tutorial Files > analyze_frame.iam
Right click Edit the Frame0001
Right click Edit with Frame Generator the first frame member.
What happens?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Where do you find that tutorial file?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
http://usa.autodesk.com/adsk/servlet/index?siteID=
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
JDMather u help to all of the people? or any one u want?
freedom for Iran
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
JDMather:
Thank you for your response. I tried what you said and have the same issue. Attached is a screenshot of my problem. as you can see there is no dialoge box in sight. Do you have any idea what the problem could be? Thanks
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Your screen capture would have been a little more informative if you and first clicked on the Design tab.
Sure looks like you are in Frame Generator edit mode but the dialog box is somewhere off-screen.
Are you or have you ever used dual monitors with this box?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
bms953 wrote:JDMather u help to all of the people? or any one u want?
I answer the easy questions if I think I know the answer.
About the only things I know are - "Sketch1 isn't constrained" and "an iam without ipt files is useless". ![]()
If you stay here a while you will see that I have copied those two responses here around 19,000 times.
