• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    Frame Generator Not Inserting Part
    377 Views, 13 Replies
    01-27-2013 02:39 AM
    Hi, all
    Im using frame generator, i create my skeleton part, start up frame generator, select my frame types and connect them to the lines, press OK, accept the default filenames then get this error:
    [WARNING] Frame Generator: Errors occurred during inserting Frame Member(s)
        [WARNING] Insertion of frame member(s) failed
            [ERROR] A frame member could not be created.  The template file for ANSI ANSI AISC (Rectangular) - Flat Bar Steel could not be located in the Content Center library.
    and no parts are put in the assembly.
    I have updated the content centre etc and installed all the latest updates. I have also reinstalled Inventor and The local content centre but the error persists.
    Ive included a couple of screen shots that show the error.
    Please help as frame generator is useless until this is fixed and i need to design some frames.
    Thanks for help in advance.
    w7u-64sp1,iv13sp1.1,intel.xeon.e5-2620 0 @2.00 2.00-32gb,gtx560-4gb
    Please use plain text.
    Curtis_Waguespack
    Re: Frame Generator Not Inserting Part
    01-27-2013 07:32 AM in reply to: cmharb
    Hi  cmharb,
    You might want to check your project file and ensure that the Conent Center libraries are configured/included for it.
    See the Configure Content Center Libraries topic listed under Procedures at this link:
    http://wikihelp.autodesk.com/Inventor/enu/2013/Help/1310-Autodesk1310/1655-Assembli1655/1779-Content...
    I hope this helps.
    Curtis
    Here's an image of the Configure dialog I found in another thread, you should see the ISO library listed as shown:
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    Active Contributor
    01-27-2013 01:56 PM in reply to: Curtis_Waguespack
    Yea they are all there.
    The Bolt generator and Content Centre work fine, I can even insert Frame parts from the Content Centre but not using the Frame Generator
    Active Contributor
    02-08-2013 03:06 PM in reply to: cmharb
    can no one help me with this?
    blair
    02-08-2013 04:02 PM in reply to: cmharb
    Can you try a different CC library other than ISO
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 320.18
    SpacePilot Pro 3.16.3 / 6.16.0 / 4.11
    Active Contributor
    02-09-2013 12:01 AM in reply to: blair
    yea, happens on all
    blair
    02-09-2013 07:47 AM in reply to: cmharb
    Can you check the ISO library properties and file size
    Win7-64
    blair
    02-09-2013 07:53 AM in reply to: blair
    Can you get to this point?
    Win7-64
    Active Contributor
    02-10-2013 02:00 AM in reply to: blair
    yup, have a look at the images i posted on my first post. It gets all the way through the wizard sequence and just when the part is supposed to appear i get the error message.
    the content centure is on the vault, and doesnt show size etc.
    blair
    02-10-2013 08:19 AM in reply to: cmharb
    Probably a problem with your Vault settings then.
    Win7-64
