Can anyone tell me if correct_g_l_parameter.zip hotix for non-updating FG parameter G_L is contained in SP1 for 2012?
The hot fix is included in the SP1.
So, installing the SP1 the problem doesn’t happen anymore.
By the way, to correct the G_L value in R2012 frame generator assemblies that were created prior to applying the hotfix or the SP1, in case you didn’t install the hot fix, you will have to do a one-time clean-up operation of each assembly as explained in the solution TS17347163
I hope I’ve clarified this for you.
Kind regards,
Alessandro
