• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    Accepted Solution
    Frame Copy
    228 Views, 8 Replies
    10-18-2012 06:14 AM
    I have made a Door with Frame Generator and I want to make an other one like this with higher height. So I copied and
    pasted the files of Frame with windows explorer and then changed the Frame Height of the new file assembly. But that changed the height of the first door also. I guess because the new door is still related with the old frame. What can I do to copy frame objects that I want to change partially
    Please use plain text.
    Distinguished Contributor
    Re: Frame Copy
    10-18-2012 07:22 AM in reply to: ghmail16
    use copy design
    *Expert Elite*
    Curtis_Waguespack
    Re: Frame Copy
    10-18-2012 07:35 AM in reply to: ghmail16
    Hi ghmail16,
    Depending on the version of Inventor are you using, you might be able to use the iLogic Design Copy tool. It was included in the 2012 and 2013 versions. It will copy and update the internal links of the frame. Note that you don't need to have used iLogic to use the iLogic Design Copy tool.
    http://wikihelp.autodesk.com/Inventor/enu/2013/Help/3364-Show_Me_3364/3365-Show_Me_3365/3747-iLogic3...
    The Copy Design tool in the SDK will work as well.
    Paul covers both of these tool here:
    http://cadsetterout.com/inventor-tutorials/the-secrets-of-copying-assembly-files/
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    Re: Frame Copy
    12-17-2012 10:53 PM in reply to: Curtis_Waguespack
    I used
    Tools>iLogic>iLogic design copy
    but with Inventor open and all files closed.
    Thanks for the help.
    Active Contributor
    JorisSteurs1246
    Re: Frame Copy
    04-26-2013 08:57 AM in reply to: Curtis_Waguespack
    Hi Curtis
    When I would do this workflow, i get a message that the skeleton could not be copied and that the origingal skeleton wil be used. This is not good because your original frame will be messed up when making changes at the new frame.
    Is there a work around for this?
    Joris
    *Expert Elite*
    cbenner
    Re: Frame Copy
    04-26-2013 10:11 AM in reply to: JorisSteurs1246
    For frames and tube & pipe assemblies, I've always had good luck with Vault copy design.  But... you have to be using Vault.  :smileytongue:
    ChrisB
    Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
    Active Contributor
    JorisSteurs1246
    Re: Frame Copy
    04-26-2013 11:38 AM in reply to: cbenner
    Yep, Stand alone user, tried Vault many years ago but it slowed me down,
    didn't allow me to go picking parts in old folders and some
    other annoyances, so I didn't use it anymore since.
    Joris Steurs
    Design & Fabrication
    www.distep.ee
    *Expert Elite*
    cbenner
    Re: Frame Copy
    04-26-2013 12:01 PM in reply to: JorisSteurs1246
    I agree Vault has it's share af annoyances, but I'd be lost without it.
    Have you tried Design Assistant?  I've never used it with FG, so I don't know how it handles the skeletons.
    ChrisB
    Active Contributor
    JorisSteurs1246
    Re: Frame Copy
    04-26-2013 12:10 PM in reply to: cbenner
    Yes DA gives the same complaint as the ilogic copy design tool.
    Joris Steurs
    www.distep.ee
