• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    Frame Analysis Node Release Example
    207 Views, 1 Replies
    10-08-2012 03:33 AM
    Could someone please explain the circumstances where 'Release' is applied to a beam (node?) when using the Frame Analysis tool.
    MES
    Please use plain text.
    Employee
    Re: Frame Analysis Node Release Example
    10-08-2012 12:39 PM in reply to: MarkESmith
    Hi Mark,
      If the frame is to be analyzed as a truss (i.e. members are pinned together instead of being regarded as fixed to each other) you can add releases to the rotational DOFs specifying 'uplift - none'.
      The members with the uplift none rotational releases will be analyzed as two-force members, where they cannot hold a moment load (unless you apply gravity, then there will be bending moment loads within the beam).
     I hope this helps...
    Thanks, -Hugh
    *Please press the 'accept as solution' button if this thread answers your question, so others can quickly benefit*
    Hugh Henderson
    Simulation QA Engineer
    DLS (Simulation and Material Sciences)
