• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    Vitornis
    Forcing a flat Pattern to a Specific Length
    291 Views, 6 Replies
    12-06-2010 01:33 PM
    Is there a way for forcing a flat pattern, when unfolded, to a specific length?
    Please use plain text.
    **Master
    Re: Forcing a flat Pattern to a Specific Length
    12-06-2010 01:38 PM in reply to: Vitornis
    The countour roll tool (Inventor 2010 and beyond) has the ability to specify the developed length.
    what kind of part are you making?
    can you provide a simple example file?
    Valued Contributor
    Vitornis
    12-06-2010 01:42 PM in reply to: BMiller63
    Trying to make a rolled cylinder out of Max length sheet of 96in. The Diameterof the cylinder is 96in as well.
    **Master
    12-06-2010 02:30 PM in reply to: Vitornis
    Contour Roll with the Developed Length option is what you want.
    see attached example IPT (2010 format) for how to set up the sketch
    2362i28D56B861E58B9B4
    Valued Contributor
    Vitornis
    12-06-2010 03:10 PM in reply to: BMiller63
    In your example  shouldn't there be one pattern 96in long and another that will be the remain of the circumference?
    Distinguished Mentor
    12-07-2010 05:59 AM in reply to: Vitornis
    I'm guessing, but is this what you mean?
    Valued Contributor
    Vitornis
    05-03-2012 03:13 PM in reply to: rdyson
    What I'm looking for is I want Inventor to tell me how much stretch i would get rolling a 10ft plate to a certain radius.  Or if that is not possible how would you got about calulating the stretch from the Kfactor parameters?
