• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    *Germer, Ole
    Fold Error
    38 Views, 3 Replies
    11-22-2002 10:13 PM
    There is an error in the fold options. This is pretty bad!
    I am bending a 5/16 sheet using fold. The sheet is finished trimmed and
    then folded 1 1/2 inches in from a 45 degree cut in the sheet. The fold is
    90 degrees. The final location is the third choice in the Fold:Fold1 pick
    window. That means the final position of the physical bend is fixed with
    this option. The actual brake press point of hit is back relative to
    Kfactor.
    If I change the Kfactor, the actual width of the strip that got bend
    should change relatively but the final position should remain the same.
    BOTH CHANGE when I do this. This is not a computer code error but
    rather a DRAFTING ERROR and a misunderstanding of the part of the
    programmer.
    I will post my example in customer-files.
    Ole Germer
    Helping create better involute profiles for gears
    http://www.geocities.com/olegermer/index.html
    Please use plain text.
    *Adams, Brad
    Re: Fold Error
    11-25-2002 07:08 AM in reply to: *Germer, Ole
    I don't agree with you. If you change the Kfactor the part will grow or
    shrink accordingly. The Kfactor is trying to determine the amount of
    material it takes to go from the start of your bend to the end of the bend.
    So a bend at a Kfactor of .5 will use up more of the material to complete
    the bend than a bend with a Kfactor of .2. So if you fix it so that the
    start of the bend is 1.50" from the edge and it takes .589" (at a Kfactor of
    .2) of material for the bend whatever material is left will end up for the
    flat area between the end of the bend and the edge. But with the Kfactor of
    .5 it uses .736" of material to make the bend and since you still started
    the bend at 1.50" from the edge you will have less material left over for
    the flat area after the bend.
    Because you are not measuring at a right angle to the bend the differences
    between the 2 Kfactors is much greater than if you where to measure at a
    right angle to the bend.
    *Germer, Ole
    Re:
    11-25-2002 07:47 AM in reply to: *Germer, Ole
    "Brad Adams" wrote in message
    news:752ACA33732EDD487760E39041B0EC52@in.WebX.maYIadrTaRb...
    bend.
    The choice was fix the final point. Change the other parameters. That is
    what Inventor implies with their dialogue location picks for .
    of
    of
    If you measure at right angle there is still a difference.
    Finally:
    It finally dawned on me. My approach is maybe a little wrong. If I stick a
    dimension from the upper right angled corner to the bend line, and make the
    1.5 inches to the fold driven, the result should be what I expect. Changing
    the kFactor does not change the final position of the flange, only the
    width of the flange. You give it try.
    It is still wrong.
    Ole
    *Autodesk\
    Re: Fold Error
    11-25-2002 08:25 AM in reply to: *Germer, Ole
    There is nothing wrong with this part. You dimensioned the bend line 1.5"
    from the edge. You selected the option that the bend line defines the end of
    the bend. In each of your examples, the end of the bend is 1.5" from the
    edge. It is doing exactly what you are telling it to do.
    Loren Jahraus
    Autodesk Inventor Workflow Team
    "Ole Germer" wrote in message
    news:F39F003FA65AF78B465F88F8593D9FD3@in.WebX.maYIadrTaRb...
    > Kfactor.
    > programmer.
    > Ole Germer
