• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    Flexible Hinges
    312 Views, 6 Replies
    01-17-2013 11:13 AM
    I am working on a hinged door assembly that consists of a frame sub-assembly, and 2 door panel sub-assemblies that each have 4 hinged sub-assemblies that I have made flexible. I am trying to figure out how to constrain these doors so that they "operate" correctly and not spin 360 degrees when I manipulate them in the overall assembly.
    Thanks for the help,
    Anderson
    Please use plain text.
    Curtis_Waguespack
    Re: Flexible Hinges
    01-17-2013 11:42 AM in reply to: anderson51
    Hi anderson51,
    If you create a constraint limit in the subassembly, and then make the subassembly instances flexible at the top level assembly, I think you should get it to work:
    http://wikihelp.autodesk.com/Inventor/enu/2012/Help/3320-Show_Me_3320/3321-Show_Me_3321/3481-Assembl...
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    Re: Flexible Hinges
    01-17-2013 12:08 PM in reply to: Curtis_Waguespack
    Hello, I keep getting an error message when trying to enter a min/max value. Don't know if it matters, but I have one of the hinge leafs grounded in the sub assembly?
    *Pro
    Re: Flexible Hinges
    01-17-2013 06:06 PM in reply to: anderson51
    Can you zip up and post your door and hinge assembly and parts?  What version of Inventor are you using?
    Sam B
    Inventor 2012 Certified Professional
    Please click "Accept as Solution" if this response answers your question.
    Inventor Professional 2013 SP1.1 Update 1
    Windows XP Pro 32-bit, SP3
    HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
    SpaceExplorer/SpaceNavigator NB, driver 3.7.18
    still waiting for a foreshortened radius dimensioning tool in Drawing Manager
    Re: Flexible Hinges
    01-18-2013 10:56 AM in reply to: anderson51
    I couldn't attached the entire assembly as it was too large of a file, but i did attached the parts in question.
    Thanks for the help.
    Curtis_Waguespack
    Re: Flexible Hinges
    01-19-2013 07:32 AM in reply to: anderson51
    Hi anderson51,
    I just tested this using your files and it works as expected. Unfortunatly I can't post the files back due to the Inventor version I'm running at the moment, but here is a screen shot showing the selections and inputs for the angle constraint with limits on the hinge:
    I hope this helps.
    Curtis
    Re: Flexible Hinges
    02-07-2013 10:25 AM in reply to: Curtis_Waguespack
    Thanks for your help!
