• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    gcross
    Flat Pattern with Rib features
    197 Views, 3 Replies
    12-14-2012 05:33 PM
    My flat pattern of a sheet metal part fails when I added strenthening Press ribs to the middle of the part using an iFeature.
    I know Inventor is not capable of flattening embossed sheetmetal but is there a way to still get the flat pattern & ignore the formed areas?
    Seems to me I was able to add some model features in the past like bosses, extruded holes KO's etc & I could still make a flat pattern.
    I know I can use derived part to do it but that adds complications.
    Gary
    IV 2012 SP2
    Inventor Suite 2013 Ultimate
    Please use plain text.
    *Expert Elite*
    Re: Flat Pattern with Rib features
    12-15-2012 09:06 AM in reply to: gcross
    Use sheet metal Punch tool for those ribs.  (a Punch tool is a special iFeature)
    gcross
    12-17-2012 11:12 AM in reply to: gcross
    Hi JD,
    Is it as simple as adding a center mark to the Press Rib ide file &moving the ide into the punch folder from the other folder or do I need to create a Press rib tool from scratch? This is a compicated iFeature tool & I'm not sure about being able to reproduce it.
    Gary
    *Expert Elite*
    12-17-2012 12:50 PM in reply to: gcross
    A little more to it (not much) than adding center mark and location.
    When you create the iFeature there is a tickbox for Punch tool.
    I always create my iFeatures as Punch tools whether they really are punches or not.
