Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Flat Pattern not shown
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
When I open an older sheetmetal ipt, and then click "Go to Flat Pattern"... the flat pattern is not shown. I can go to the idw that has the flat pattern detailed and it is there, just not shown in the ipt. I have attached the a sample part. This does not happen on every sheetmetal part that I open, just a few.
Any ideas on how to get this show up?
Re: Flat Pattern not shown
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Kar,
Have you overlooked the sheet metal rule? I have cheked into the file and it looks like the sheet metal rule was .1046in and the sheet metal thickness on the model is .105in. I deleted the flat pattern and made a new flat pattern see screen shot. These settings should be the same when unfolding sheet metal. Hope that helps. Apology if I have misunderstood in any way your question as I'm just new here in this forum.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I checked the sheetmetal rule and it is set to .1046in and the Thickness shown in the part parameters is .1046 as well.
I can delete the flat pattern and have it regenerated in the ipt. Problem with this is that the flat pattern is already detailed on a sheet and I will then lose all the dimensions on the view. I would rather not have to redimension it.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I just did a rebuild all and it appeared.
wonder if it's down to a rounding error, as you say it should be 0.1046 but the sketch displays 0.105, and thus somewhere it could being seeing this rounding-error and thus a mis-match between model and sheet-metal thickness. Would increasing the number of decimal places in the document settings help prevent this?
Please mark this response as "Accept as Solution" if it answers your question - but note that the solution may not be the answer you're wanting to hear...
Lithium - helping nntp users with mania, depression and headaches
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Kar,
I confirm thickness is 0.1046in when I change the precision for measurement. For some reason INV is hiding it from you or as Sam mention it could be the precision setting.
You wrote : Any ideas on how to get this show up?
Freshly I opened the IPT and make an RMB on the browser and and choose "Edit Flat Pattern Definition" and viola your pattern showed up.
No Need to rebuild.
Cheers!!! I hope that helps..
macflirty
