• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    cjj
    Active Member
    cjj
    Flat Pattern Save to DWG/DXF Fails to Initialise.
    656 Views, 6 Replies
    09-05-2010 06:51 AM
    When I try to save a flat pattern to dwg format using the default DWG Configuration; I repeatedly get the error message “Sketch export failed to initialize the document.”
    There is not a problem if I choose the *.SAT option which makes me suspect that it is a configuration file problem.
    Can anyone help please it is driving me quite mad!
    I am running Autodesk Inventor Professional 2009 32-Bit SP2
    ****Sage
    Re: Flat Pattern Save to DWG/DXF Fails to Initialise.
    09-05-2010 07:55 AM in reply to: cjj
    Attach the file here.
    Autodesk Inventor Certified Professional
    Inventor Professional 2012 Edu 32-bit
    Still waiting for -Draft option on any Rib feature. -Properties Painter.
    Still wondering why Edit Form is above Edit Feature on RMB?
    cjj
    Active Member
    cjj
    09-05-2010 08:50 AM in reply to: JDMather
    It occurs with any file, even a simple rectangular plate. Even If I create a configuration file and save it.
    I have repaired the software to no avail. This has been a recurring problem for me with successive Inventor releases.
    One day the export works another it doesn't.
    I have attached one of the offending files for your kind attention.
    Thank you.
    Christopher
    ****Sage
    09-05-2010 09:02 AM in reply to: cjj
    I don't believe your part is modeled correctly - the sides in the flat are not perpendicular to the flat.
    Where is the feature history to determine where you went wrong on the modeling.
    The flat does save fine to dwg on my machine (2011).
    cjj
    Active Member
    cjj
    09-05-2010 09:17 AM in reply to: JDMather
    My apologies.
    The file I wanted to send was too big.
    I have attached a standard tutorial file that wii also not save except to SAT format.
    Thank you for your kind asistance.
    Christopher
    ****Sage
    09-05-2010 11:02 AM in reply to: cjj
    Christopher
    For large files drag the red End of Part marker to the top of the browser hiding all features.
    Save the file in a rolled up state.
    In Windows Explorer right click on the file name and select Send to Compressed (zipped) Folder.
    Attach the resulting *.zip file here.
    I am not having any trouble with the files you have attached - so the problem must be with your install.
    cjj
    Active Member
    cjj
    09-05-2010 11:23 AM in reply to: JDMather
    Thank you for your further kind reply.
    I too am pretty certain the problem is programme related.
    I will un-install Inventor and re-install.
    In the meantime thank you for your kind assistance.
    Christopher
