• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    lemaycj
    File Sharing
    228 Views, 5 Replies
    07-18-2012 10:34 AM
    I am looking for a resolution for file sharing between Inventor from Product Design Suite Premium 2012 & Inventor from Product Design Suite Standard 2013 for two users.  I have no problem going from 2012 to 2013 obviously but the other way around: if a .idw is saved with 2013 it can't be opened with the 2012 program.  How do we work around that?  I was thinking we need to save from the 2013 into a 2012 format but don't know where to set that up.  Here's the message I get in 2012:
    "Database schema for file path\50038.idw is (17.0(Build 170095000, 95)), which is newer than this version (16.0SP1 (Build 160190100, 190)) of the software"
    Please use plain text.
    Re: File Sharing
    07-18-2012 10:53 AM in reply to: lemaycj
    The proper way is to upgrade the 2012 user to Inventor 2013.. Thats it.
    3d cad program native formats are NOT backward compatible.
    Please click "Accept as Solution" if this response answers your question.
    2012 Product Design Suite Ultimate
    Windows 7 64 bit
    90G OCZ SATA 3 SSD (My SSD is faster than your HDD)
    Core I7 920 processor, ATI HD6970 graphics card, 12G Corsair RAM
    Valued Mentor
    jclaidler
    Re: File Sharing
    07-18-2012 10:59 AM in reply to: lemaycj
    You need to have everyone on the same version of Inventor.  3D parametric solid modelers are not 'backward' compatible.
    _______________________________________________________________
    ITO - Application Management
    Factory Design Suite Ultimate 2012
    AutoCAD 2012 | Inventor Professional 2012 | Vault Professional 2012
    Member
    Re: File Sharing
    10-05-2012 05:24 AM in reply to: lemaycj
    We have recently had a similar problem in that existing files will not open in the SAME version of Inventor that they were created. We get the message 'database schema etc', but we haven't upgraded our software as we are still running on Inventor 11. No files have been created in a later version.
    Has some other download such as DWGTrueview12 caused our existing files to be upgraded??? If so this is a bit rich and unforseen as we now can't access our records/ data base. Has anyone else got this problem and are there any answers or solutions other than upgrading at great cost??
    mrattray
    Re: File Sharing
    10-05-2012 05:45 AM in reply to: edwardtg
    I suggest you start a new thread. Your problem is different from this one, as the OP's poblem was normal behaviour whereas the behaviour you're describing is not. When you create a new thread you should post one of the problem files.
    Mike (not Matt) Rattray
    Member
    Re: File Sharing
    10-05-2012 06:40 AM in reply to: lemaycj
    ok WILL DO
