• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    karthur1
    File Open dialog
    489 Views, 10 Replies
    06-30-2010 11:15 AM
    Just say that I need to open a file and browse to the file location and open it.  The next time that I  open a file, Inventor now goes to the previous folder location, but does not save the prior filename.
    I could be wrong, but I thought that 2009 would go to the folder location and also retain the filename.  So the previously opened file would be highlighted in the file open dialog.
    I am running 2010,Adv sup pack #3.  Could someone that is running 2009 or 2010, no sp test this and see what they get?
    Please use plain text.
    blair
    Re: File Open dialog
    06-30-2010 11:37 AM in reply to: karthur1
    Not in IV2010 anymore, but with IV2011 it defaults to the last folder/directory opened regardless of the IPJ. Even  if you close IV2011, then select open, you get your last directory and not your Work Directory from the IPJ.
    It seems it get fixed in one SP and then changed in the next SP.
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 314.07
    SpacePilot Pro 3.16.1 / 6.16.0 / 4.11
    06-30-2010 12:00 PM in reply to: karthur1
    I'm using Inv. 2010 SP3 and it remembers the last file and path when I open.
    Same thing for Open from Vault.
    If I change project files, then it goes to the workspace folder.
    Mike
    karthur1
    06-30-2010 12:14 PM in reply to: Mike_Maenpaa
    Mike,
    My 2010 retains the filename of the previously opened file, but it does not highlight it in the open dialog.  I still have to pull the vertical bar down to find the previously opened file.
    In this video, I have just opened and closed the -041 part number.  Now I want to open up a -043, which is just below it.
    http://screencast.com/t/YzQwMDM3
    I thought that it used to highlight the previous file in the file open dialog.
    This is one thing that I do like about Autocad (2010).
    06-30-2010 12:23 PM in reply to: karthur1
    karthur1 wrote:
    Mike,
    That's how it is working here.
    Mike
    06-30-2010 01:45 PM in reply to: karthur1
    I think you are right, karthur1.  I remember 2010 used to highlight the last-opened file in the open dialogue.  I noticed that it stopped doing this right about the time that I upgraded from Win XP 32 to Win 7 64.  But, I also got SP3 at the same time.  Maybe it's the OS change, maybe it happened in SP3?  I'm not sure.  Whichever it is, it is really annoying.  That seemingly insignificant behavior was built into my subconscious workflow.  Now that the behavior has changed, I find that my workflow hiccups now and then, and it is frustrating.
    -cwhetten
    IV2010 Professional SP3
    Build 551 Subscription Advantage Pack
    Windows 7 Pro 64-bit
    Dell T3500, Intel Xeon Duo 2.40 GHz, 6 GB RAM
    NVIDIA Quadro FX 1800, 768 MB
    Driver Ver: 197.85
    Dual Monitors, 1280x1024
    06-30-2010 01:51 PM in reply to: cwhetten
    I'm on XP 32.
    Like I said before, it works for me.
    I wish it would put the focus on the file list, so that I could scroll with the mouse wheel instead of having to click there first.
    Mike
    karthur1
    06-30-2010 02:01 PM in reply to: cwhetten
    I was on Inv 2010, Adv Sup Pack 3 running XP-32 bit.  We changed to Win7-x64 and I notice it now, but I was not sure when they sneaked it in.  It sounds now like the two OS are different.
    Yes, it is very annoying.
    Maybe when AD gets back from vacation, they will repsond to this.
    Kirk
    karthur1
    06-30-2010 02:22 PM in reply to: Mike_Maenpaa
    Mike,
    Sounds like a good "wish list" item.
    http://www.mcadforums.com/forums/viewtopic.php?f=5&t=11271
    New Member
    pwoolfrey
    07-19-2011 12:27 PM in reply to: karthur1
    This exact problem has been driving me crazy until today.  I seemed to have unknowingly solved it.  I've since done this on  a co-workers machine and it also worked.  I'm running Inventor 2011 (64-Bit Edition).  All I did was this:
    Download and Install from KwikMcad, the utility call KwikSert.  I use this religiously and it saves a ton of time.
    http://www.kwikmcad.com/icode/KWiKSert_64/KWiKSert_64.aspx
    Once this was installed, and I re-started Inventor, voila, File-Open automatically takes me to the last file I opened.  If anyone can explain this, I would be interested in hearing why this fixed it.
    Cheers!  If this works for anyone else, post and let us know.
    Seems like the good folk at KwikMcad have now resorted to solving problems without even knowing it.
    Peter Woolfrey
    Ontario Drive & Gear
    Space / Robotics Division
