• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Feature Recognition 2012 not working
    739 Views, 12 Replies
    11-02-2011 05:02 AM
    This is issue in Autodesk Inventor Professional 2012. After installing Feature Recognition x64 bit 2012, its installing successfully. But its not showing in Add-in manager and is not working. So kindly suggest me in this regard.
    Prasanth Pakalapati
    Please use plain text.
    Product Support
    Re: Feature Recognition 2012 not working
    11-03-2011 07:56 AM in reply to: prasanthpakalapati
    You may be better off posting this to the Labs email site. But in reviewing this I did notice that there are different versions of the feature recognition tool. I loaded the 2012 version and it shows in my add-ins. Another thing would be to do the installation as Local Administrator or run as Administrator
    MariaManuela
    11-03-2011 08:11 AM in reply to: prasanthpakalapati
    Hi.
    Have you tried the feature recognition that already inside Autodesk Fusion?
    Maria Manuela Pinho
    Application Enginner
    Cadtech.Asidek | Autodesk Gold Partner
    http://cadtech-asidek.blogspot.com/
    www.cadtech.pt | www.cadtech.es | www.asidek.es
    Autodesk Inventor Professional 2013
    Windows 7 Professional 64-bit
    11-03-2011 09:13 AM in reply to: prasanthpakalapati
    I just installed on 2 32-bit machines.
    On one it works - on the other - nothing?
    Inventor Professional 2014 Edu 64-bit
    Active Contributor
    12-08-2011 08:24 AM in reply to: JDMather
    Hey Guys,
    I think I got it to work after spending a good 3 hours on it! its simple, how stupid I was not think about it sooner, all you need to do is manually register the dll file which is located under inventor 2012\bin\featurerecognition.dll through regsvr32.exe command. how? ok, start menu, run, punch in cmd and enter, then navigate to c:\program files\autodesk\inventor 2012\bin\ and then type regsvr32 featurerecognition.dll. then it should work. make sure inventor is not running when you do this.
    trust it helps
    Sincerely
    Ali
    Warm Regards
    New Member
    info
    03-09-2012 02:55 AM in reply to: 3DAli
    @3DAli:
    You are a real life saver! Manually registering the dll works like a charm. Many thanks!
    Best Regards,
    Maurice
    ALUMATZEEMAN
    Active Contributor
    03-11-2012 04:30 PM in reply to: info
    Youre very welcome Maurice, I'm glad it helped :smileywink:
    Cheers
    Ali
    Warm Regards
    Active Member
    DPLOWMAN5757
    10-17-2012 11:25 AM in reply to: prasanthpakalapati
    I have manually register the .DLL file and it shows up in the Add-in manager, but it does not show up under any of the tabs. How do I access the feature? Please help
    10-17-2012 11:57 AM in reply to: DPLOWMAN5757
    I don't see any solid features in your screen capture - only a 3D sketch?
    Expand the feature tree here
    Active Member
    DPLOWMAN5757
    10-17-2012 12:05 PM in reply to: JDMather
    My problem is that I was sent a *IGS file, which comes in as wires, but I would like to convert it into a solid *.IPT
