• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    Feature Control Frame Edit Unit Attributes Use Standards Notation
    109 Views, 1 Replies
    04-03-2012 03:57 PM
    Autodesk Inventor 2010 - How do I set default for "use standards notation" to off or unchecked in the "Edit Unit Attributes" dialog box for feature control frames? I want to do this because the Feature Control Frame style unit setting does not override it as I believe it should. This causes an extra value within the tolerance box of the feature control frame if the Standard General units differ from the style’s primary units.
    Please use plain text.
    Product Support
    Re: Feature Control Frame Edit Unit Attributes Use Standards Notation
    04-06-2012 07:15 AM in reply to: sgreene
    I had a look at your image, and since you have your Inventor Project option for "Use Styles Library" set as no, you'll need to make the changes you want (if possible), and then save this drawing as a template. You can either replace the default Standard or save it as a new file in the Template folder structure.
    When you start a new drawing and use this template, those changes should applied.
    Dave Anderson
    MFG Support - Inventor
    If I have answered your question, please "Accept Solution" so others may benefit as well.
