• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Factory desing suite 2013 Inventor crashes
    132 Views, 3 Replies
    11-19-2012 10:17 AM
    Inventor crashes after starting a part file, the crashes almost immediate. I have installed service pack 1 and 2. I have attached crash logs for further reference.
    using HP Workstation Laptop with I7 processor, 16GB Ram, Nvidia Quadro 3000m Graphics Card on Windows 7 64
    Prem
    Please use plain text.
    blair
    Re: Factory desing suite 2013 Inventor crashes
    11-19-2012 02:36 PM in reply to: prem
    Is this a new install? Has Inventor worked previously on this machine (existing install)?
    You followed all the pre-requisites for the install:
    1.) logged in with Admin privileges
    2.) UAC slider set to lowest setting
    3.) Current on all Windows SP's and Hot-fixes,
    4.) .NET 4.0 installed on machine
    5.) You have the current Microsoft certified graphics card drivers for your machine
    6.) You have the SP1.1 for Inventor installed
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 314.07
    SpacePilot Pro 3.16.1 / 6.16.0 / 4.11
    11-19-2012 09:23 PM in reply to: blair
    Got the solution
    It has something to do with Autodesk Cloud Account signed in, once i sign out everything works fine
    regards
    Prem
    Product Support
    11-22-2012 07:36 PM in reply to: prem
    I have checked your Critical error Report from you. Some of the CER is contacted with known defect with ACM2013 which has been fixed in Sp1. Please patch it from below link.
    AutoCAD Mechanical 2013 Service Pack 1
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20546317&linkID=9240898
    Service Pack 1 for Factory Design Suite 2013
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19817524&linkID=15639656
    Service Packs 2 for Factory Design Suite 2013
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20484229&linkID=15639656
    Yong Jing
    Product Support Specialist
    Frontline Technical Support, CSS. GCSO
