• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    *Bryan, Jason
    FEA Packages for Inventor??
    124 Views, 7 Replies
    12-16-2002 04:07 AM
    Does anyone out there know of a good FEA software package for use with
    Inventor? I am looking for something to use for a small business. Nothing
    really expensive like Algor. I just need something simple to use that is
    sort of cheap but a good package.
    Jason
    Please use plain text.
    Distinguished Contributor
    Re: FEA Packages for Inventor??
    12-16-2002 04:11 AM in reply to: *Bryan, Jason
    We use COSMOS/DesignStar 3.X. The Inventor integration often causes it to crash so you are better of exporting the file and importing it. It is pretty easy to use, but can be VERY slow. I suspect it isn't the most sophisticated FEA package on the market. To be honest I don't use it much, I never have the time to learn it real well and have found that if you don't know it real well your results are suspect. I don't have any experience with other packages to compare. Well OK we had Algor for DOS long ago, complete with CGA graphics ....
    Rich Thomas
    *Dotson, Sean
    12-16-2002 04:12 AM in reply to: *Bryan, Jason
    DesignSpace from Ansys. Easy to use and it interfaces directly with
    Inventor.
    http://www.ansys.com/ansys/designspace.htm
    you can get a 30 day trial from this page as well. Not sure if the R6
    update is out yet but at the least you can save as SAT and import from
    there.
    Sean Dotson, PE
    http://www.sdotson.com
    Check the Inventor FAQ for most common questions
    http://www.sdotson.com/faq.html
    "Jason Bryan" wrote in message
    news:B1CA35F3D4A68E931A706DB9B43322B8@in.WebX.maYIadrTaRb...
    Nothing
    > Thanks,
    > Jason
    *Autodesk\
    Re:
    12-16-2002 04:46 AM in reply to: *Bryan, Jason
    Hi Rich,
    Take a look on the Inventor Certified Partner
    Applications.
    All the best,
    jeferson.stutz
    color=#006699>@autodesk.com
    face=Verdana>
    Manufacturing
    Application Engineer
    Southern Latin America
    face=Verdana>
    Rua Florida, 1758 - Andar
    7
    Sao Paulo, SP 04565-001
    color=#006699>Brasil
    Direct phone: 55
    11-5505-0275
    Fax : 55 11-5505-0232
    autodesk
    color=#006699>®
    We
    Rich Thomas
    *Bryan, Jason
    12-16-2002 05:02 AM in reply to: *Bryan, Jason
    Has anyone used Lisa with Inventor?
    http://www.lisa-fet.com/index1024.htm
    Nothing
    > Thanks,
    > Jason
    Valued Contributor
    Re:
    12-16-2002 08:38 PM in reply to: *Bryan, Jason
    I used a trial of designspace about a month ago. It's pretty cool. Easy to learn and fairly quick to run solutions. Thats about all I did for a month. I got decent on it. Picked it up with a little help from the "help" lines at ansys in no time. I advise no one to buy FEA programs that can't calculate at least the most basic stress analysis problems by hand though. I have done quite a bit by hand, and I still almost let some screwed up solutions slide by. There are infinite ways to get bad results.
    *Dotson, Sean
    Re:
    12-16-2002 09:03 PM in reply to: *Bryan, Jason
    "I advise no
    bad results."
    This is so true.  One of the things I was
    taught in college is that you had better know the approx solution before running
    an FEA.  It's basic function is to "back up" your theory.  I've lived
    by that rule to this day.
    Sean Dotson, PE
    href="http://www.sdotson.com">http://www.sdotson.com
    Check the Inventor
    href="http://www.sdotson.com/faq.html">http://www.sdotson.com/faq.html
    I
    Re:
    12-16-2002 10:45 PM in reply to: *Bryan, Jason
    I was actually opposed to us purchasing an FEA package with a floating license and rolling it out to anybody and their brother for just that reason. I lot the argument :smileyhappy: - Rich Thomas
