• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    GSE_Dan_A
    FEA Capable to simulate a PL on a pipe?
    65 Views, 1 Replies
    01-18-2013 08:17 AM
    Hello all,
    I am wondering if the FEA in Inventor 2013 is capable of simulating a pipe under a point load and at what point the pipe fails.  Its a simple 2in dia pipe supported by a vertical tube with a load of 'X' centered on the pipe.
    Thanks in advance.
    GSE Consultants Inc.
    Windsor, ON. Canada
    Please use plain text.
    *Expert Elite*
    Re: FEA Capable to simulate a PL on a pipe?
    01-18-2013 09:14 AM in reply to: GSE_Dan_A
    Yes, it can do this.  But it depends on what you mean by failure.  Inventor will perform a linear analysis, so any result with stresses above the yield stress will be meaningless.  But if by failure you mean "exceeds the yield limit", then Inventor will be of use.
