• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    polloturco
    Extruding or making holes with angles
    1500 Views, 9 Replies
    05-24-2011 09:27 AM
    I am trying to make a hole or an extrusion with angle, I know that in ancient Inventor versions it was possible only by selecting the extrusion angle, in the 2009 version it is not aviable.
    My problem is that in the image I have a circular sketch over a ring's face, I need to extrude this sketch with an angle of 45°.
    Thank you for your help
    Please use plain text.
    Valued Mentor
    Re: Extruding or making holes with angles
    05-24-2011 10:25 AM in reply to: polloturco
    use on point method
    it requires an axis and work point
    http://www.youtube.com/watch?v=7Ofr1yek7HQ
    Please mark this response as Problem Solved if it answers your question.
    Ravi Kumar MB,
    i7 860 Dell Studio XPS Win 7 64 bit 8Gb RAM
    Autodesk Product Design Suite Ultimate 2012
    Email: ravikmb5@gmail.com , skype id: ravikmb5,
    Valued Mentor
    05-24-2011 12:20 PM in reply to: polloturco
    Do you mean a taper?
    When you are extruding there should be a "More" tab, that's where the taper angle is (I don't remember what it was like before or when they changed it).
    05-24-2011 03:57 PM in reply to: polloturco
    Attach your part file here.
    I don't recall anything changing with regards to this going back as far as I can remember.
    Member
    polloturco
    05-25-2011 10:36 AM in reply to: ravikmb5
    I arrived to make the hole, but in the begining is not complete, I don't know how to solve it.
    In the attached image you can see the problem.
    thank you very much for your help.
    Valued Mentor
    05-25-2011 10:46 AM in reply to: polloturco
    What I would do is make another work point using that axis and another plane (I'd use the other face of that part and "drill" in the other direction)
    Or just make another hole in the other direction
    And we all hope that Autodesk is working on a way to do this without these extra steps
    Curtis_Waguespack
    05-25-2011 10:53 AM in reply to: polloturco
    Hi polloturco,
    Typically what I do in these cases, is to use the Delete Face tool (with the Heal option selected) to clean up the hole, as shown in these images
    I hope that helps.
    Good luck with all of your Inventor pursuits,
    Curtis
    http://inventortrenches.blogspot.com/
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    05-25-2011 12:08 PM in reply to: polloturco
    Most likely no extra workplane, no workpoint, no workaxis, and no Delete Face is needed.
    Simply Revlove-cut an angled rectangle on one of the base origin workplanes going through the center of the part.
    So easy!
    Valued Mentor
    05-25-2011 05:00 PM in reply to: JDMather
    I still would rather have Autodesk develop a way to "back cut" the hole feature. (And spotface.)Spotface.png
    Valued Mentor
    05-25-2011 05:47 PM in reply to: dan_inv09
    Whenu use work point as reference
    Shift the work point slightly above the face around 5mm/10mm
    so that hole feature cuts all through
    Attached video
    Ravi Kumar MB,
