Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Extrude/Re volve on a given angle around a cylindrica l body
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I am really struggling in trying to revolve around cylidrical body on a specified angle. I understand the degrees of rotation angle, but i am looking to revolve or extrude a certain shape for the length of the shaft. Like trying to make a coil or a set of threads.
Can anyone help? I have tried to use sweep but sweep doesnt work with two sweep lines.
Re: Extrude/Re volve on a given angle around a cylindrica l body
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
If you are trying to create a rotation along a length for a coil or to cut a thread try looking at the "coil" command.
hope that helps, Sam
Please mark this response as "Accept as Solution" if it answers your question - but note that the solution may not be the answer you're wanting to hear...
Lithium - helping nntp users with mania, depression and headaches
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I've always found that the Coil feature works quite nicely for making, well, coils.
YMMV, though. The button is above and to the right from the sweep feature.
___________________________________________________________
Product Design Suite Ultimate 2013
Dell Precision T1600 (Xeon E3-1280 / 16GB / 512 GB SSD / 250 GB (Internal) / 1 TB (External) / Quadro 600)
Toshiba Satellite P755-S5269 (i7-2630QM / 8 GB / 250 GB SSD / 750 GB HDD / GT540M)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I do not seem to have that coil feature for whatever reason on my tabs?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You are in the wrong forum - you are running Inventor Fusion, not full-featured Autodesk Inventor.
You should be over here http://forums.autodesk.com/t5/Inventor-Fusion/bd-p
