Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Extrude Cut from 3D Sketch (or something like it)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I know my subject is somewhat mis-named, because I gather that you cannot really extrude from a 3D sketch, however I am looking for a way to accomplish what extruding a cut from a 3D sketch would accomplish.
The problem is this: I have a simple 2D sketch that I've projected onto a curved surface (imagine a square projected onto the outside of a hollow cylinder). Now that I have a 3D sketch on the surface of the cylinder, I want to use that sketch as a "cookie cutter" through one wall of the cylinder.
If I were to simply extrude the cut from the 2D sketch, the "cookie" is wider at the edges than at the center. I want the cut to be perpendicular to the projected 3D sketch at all points.
I've attached a simple example that illustrates my problem.
Can anyone help? Thank you in advance!
Re: Extrude Cut from 3D Sketch (or something like it)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Split and Thicken-Cut
Emboss might also be a solution.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks!
