• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    Re: Extrude Cut Multiple Solids
    01-15-2013 10:24 PM in reply to: chrisrodway
    Maybe I missunderstod this thread, my english is not the best :smileywink:. But as an answer to the first post, one cut thru multiple solids, i've attached an example file. Regards Emil
    Please use plain text.
    *Pro
    01-16-2013 07:03 AM in reply to: Emil.Lewandowski
    Interesting-- the attached file has two disjoint solids, and I am able to extrude cut through both solids without any issue.  But in the example file that Chris (OP) posted, I can't do it.  What's the difference?
    Sam B
    Inventor 2012 Certified Professional
    Please click "Accept as Solution" if this response answers your question.
    Inventor Professional 2013 SP1.1 Update 1
    Windows XP Pro 32-bit, SP3
    HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
    SpaceExplorer/SpaceNavigator NB, driver 3.7.18
    still waiting for a foreshortened radius dimensioning tool in Drawing Manager
    Active Member
    01-16-2013 07:23 AM in reply to: Emil.Lewandowski
    It also works in the file that chris posted. If deleting the cut outs, it works fine to do just one new thru both solids.
    Even with the original sketch and workplane. But I can't figure out why it doesn't work with the first original feature.
    /Emil
    Active Contributor
    chrisrodway
    01-16-2013 07:27 AM in reply to: Emil.Lewandowski
    /Emil
    Thanks Alot for your input guys out of intrest Emil which original feature that its not working with?
    Chris
    Design Engineer
    Sheffield UK
    Cheers
    Chris Rodway
    Design Engineer
    Sheffield, UK
    Active Member
    01-16-2013 07:41 AM in reply to: chrisrodway
    The one called "CUT ONE" somehow doesn't seem to work properly.
    Active Contributor
    chrisrodway
    01-16-2013 08:01 AM in reply to: Emil.Lewandowski
    Thanks for the help guys
    Ive just look into it and for some reason if you edit the feature it doesn't let you selected multiple solids, you have to delete it and make a new extrusion. Don't know why
    Cheers Everyone
    Chris
    Design Engineer
    Sheffield,UK
    Cheers
    Chris Rodway
    Design Engineer
    Sheffield, UK
