Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Extrude Cut Multiple Solids
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Is there any way in inventor to use one extrude cut feature on two different solids at the same time?
If this is possible I think it would make life a lot easier
Cheers
Chris
Chris Rodway
Design Engineer
Sheffield, UK
Re: Extrude Cut Multiple Solids
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Can you post an example file where this would be useful?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
When designing slat tools what we use to manufacture parts. I generate the part to the form of a scanned surface and create the slats.
Then I make the top and bottom tool different solids for export etc. The tools still have some features the same and I thought it would be easier to do it in one feature. Other CAD packages let you do this I thought Inventor would also. The main reason for this is i am trying to automate this design process using ilogic snd its complaining about which solid to cut.
My example file is a made up part to protect my employers manufacturing techniques.
Thanks for the interest and reply
Chris
Chris Rodway
Design Engineer
Sheffield, UK
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
If I understand the problem - it looks like you want this to be 30 solid bodies.
I don't know of an easy way to do that in Inventor.
Sounds like a good suggestion - an option to make all disjointed solids into individual solid bodies.
http://forums.autodesk.com/t5/Inventor-IdeaStation
Easiest current solution I can think of is Extrude To the surface(s) multiple times setting New Solid each time.
Another option might be to do the master as one (or more) disjointed solids and then Derive Component 30 times as surface body and then Sculpt the desired solid in each of the 30 derived files.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
If you make it so the cut goes from the side, first thru one of the solids, it works fine with one feature only.
Just choose both solids to be edited.
/Emil
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Emil.Lewandowski wrote:If you make it so the cut goes from the side, first thru one of the solids, it works fine with one feature only.
/Emil
Can you post example ipt file?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
JDMather wrote:Can you post an example file where this would be useful?
Can't post the files because they're proprietary, and we haven't brought the product to market yet, but in my application for this issue I've got an injection molded part that will be molded in a tool that's made up of three separate core / cavity sections that are stacked on top of each other. In order to make different variants, one or more of the core / cavity sections can be swapped out. As a result, I've modelled the part as 3 separate solids, derived them into individual parts and put them into an iAssembly so that I can show any of the possible combinations mold parts to make the item.
There's a couple features that start in one mold section and are carried through into another. Bosses, slots, etc. It would be really great to be able to cut a slot through both solids in one feature, rather than having to cut one at a time.
___________________________________________________________
Product Design Suite Ultimate 2013
Dell Precision T1600 (Xeon E3-1280 / 16GB / 512 GB SSD / 250 GB (Internal) / 1 TB (External) / Quadro 600)
Toshiba Satellite P755-S5269 (i7-2630QM / 8 GB / 250 GB SSD / 750 GB HDD / GT540M)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Wait, wait, hold on, wait.... ...the OP already posted the problem file.
Can you demonstrate with the technique Emil suggested how that would solve the OP's specific problem.
That is what I am interested in. I never questioned the usefulness - in fact the OP's problem attached here is a very very good example of why we should be able to easily make multiple multi-body solids.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Wait, wait, hold on, wait.... ...the OP already posted the problem file. (and that isn't an accurate quote of what I wrote)
I think we might be looking at different questions.
1. Someone posted a question about how to extrude / cut through multiple solid bodies in a single operation.
2. You posted a question looking for a part file where that would actually be a useful technique.
3. I responded describing a situation where I would find it useful to extrude through multiple solid bodies in one operation.
And yes, that was an accurate quote of what you wrote.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
LT.Rusty wrote:I think we might be looking at different questions.
Oops, you are right. I thought you were the one who posted a "solution" without example.
Time for me to go home.
