• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Extension Spring Component Generator
    264 Views, 2 Replies
    10-30-2012 10:53 AM
    Can’t seem to get it to work. No calculations required, just a 3d model.
    Want a spring od 18mm, wire dia 2mm, with 52 coils, with something like a full loop or half hook hook type.
    The dimensions I have entered in don’t seem to work.
    What is the secret here?
    Mike K
    Joburg, South Africa
    Please use plain text.
    Employee
    Re: Extension Spring Component Generator
    10-30-2012 11:09 PM in reply to: MikeKovacik4928
    Hi Mike
    Could you post your data here? Is there any error message in the extended window of design dialogue?
    Without considering calculation results, I tried and got the result if the parameters were suitable.
    Inventor Professional 2013
    Jingyi Liu
    Quality Assurance Team
    10-31-2012 10:12 AM in reply to: MikeKovacik4928
    Thanks Jingyi
    I got it eventually, by using suitable parameters.
    I notice that using design accelerator you cannot (or not that I could see anyway) draw the spring in its free position (ie fully closed)
    I therefore also drew it in ipt using conventional methods
    I did notice that I had to use a pitch of 2.01mm (slightly more than 2mm) to prevent self intersection of solid bodies.
    Also I was able to draw the hook ends a bit better than they come out in design accelerator. Also,  In accelerator the hook ends always come out parallel to each other.
    However I am not sure what the practical reason is for not having them parallel to each other (as I have drawn in spring 01 .ipt)
    However all being said and done, I don't know how the springs are actually manufactured and what a manufacturer would need to know. I am assuming the tension spring would be fully closed ( ie as I have modelled it without the design accelerator in spring01.ipt) when it is not under  load.
    I think I will speak to the spring manufacturer tomorrow to ask him a few of what his required parameters are
    Mike
    PS I can't add all my attachments - they are too big combined even when  I zip, Therefore I will only add one+ 2jpegs
