Inventor Forum
Extended Desktop - iPart / iAssembly dialog
2 REPLIES 2
LFMarshall
352 Views, 2 Replies
I just flipped the locations of my monitors for use with extended desktop.  In the past I have used my Laptop to my right and my monitor on the left and used the stand alone monitor for Inventor.  We moved our office and I switched the locations (I was hoping that it would keep put my dimension dialog on the inventor monitor, but it still on the laptop no matter where I move it) so that my laptop is on the left and monitor on the right and I use Inventor on the monitor (on the right).
It's worked well for about a week, but today I was editing an iAssembly and the dialog pops up briefly before disappearing.  I thought I would use the Alt+Spacebar and Move trick like I did with my other boxes.  However, this particular box will not come back to my screen.  I do the Alt+Spacebar and select move and I get the 4 Direction Arrow just like with other dialog boxes that move, but it never reappears.  Any suggestions for how I might get this resolved?
I've tried turning off extended desktop, didn't work.
I've tried moving inventor back to the left side (laptop side), didn't work.
thanks
Larry Marshall
Inventor 2021.2 , AutoCAD 2021, 3DS Max 2021
2 REPLIES 2
mcgyvr
in reply to: LFMarshall
See response from Matt Smith (Autodesk)
http://forums.autodesk.com/t5/Autodesk-Inventor/Dual-Monitor-Issue-when-disconnected/td-p/2201559/hi...
LFMarshall
in reply to: mcgyvr
Thanks, that seemed to do the trick.
From Matt: HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion12.0\System\Preferences\Dialog
Inventor 2010: HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion14.0\System\Preferences\Dialog
Larry Marshall
