Autodesk Inventor
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Exporting BOM Lists
- Highlight
- Email to a Friend
It would be good if there was an option to export a bill of materials in word format (.doc) instead of just Excel, is there a way to do this in Inventor 2012 ?
Re: Exporting BOM Lists
- Highlight
- Email to a Friend
Anthony,
You can RC on the BOM and select export. Then under the file types there is a .txt file
type. These can be opened up directly inside of Word.
Scott McFadden
(2 Corinthians 5:21)
- Highlight
- Email to a Friend
Thanks yes I did see that option, it would be even better if there was a direct export to .doc option instead of this so that when the .txt file appears in Word there is no need to 'customize' the data to view correctly in Word. Maybe one for Autodesk to think about in the next release.
- Highlight
- Email to a Friend
You can't do it directly, but the option is available 'Under the hood':
Check out this example from Brian Eakins:
http://modthemachine.typepad.com/my_weblog/2010/02
@CadSetterOut
Please use the
- Highlight
- Email to a Friend
At least there is an option. Might be your only one.
Scott McFadden
- Highlight
- Email to a Friend
I have another question: I have renamed some parts in the BOM list so as to enabel them to be grouped, the problem is I loose the thumbnial when doing this, can you advise on how to retain the thumbnail when renaming and grouping parts ?
- Highlight
- Email to a Friend
That makes sense to me. The Thumbnail comes from the part file. If you roll up two or more parts, how will Inventor know which one to take the Thumbnail from?!
@CadSetterOut
Please use the
- Highlight
- Email to a Friend
I am grouping exactly the same part so Inventor should retain the thumbnail image as it's the same part !
- Highlight
- Email to a Friend
Hi have a look at BOM Tools. I think it can do what you need.
http://www.mgfx.co.za/tools-for-inventor.htm
