• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    Anthony
    Exporting BOM Lists
    332 Views, 8 Replies
    03-22-2012 04:37 AM
    It would be good if there was an option to export a bill of materials in word format (.doc) instead of just Excel, is there a way to do this in Inventor 2012 ?
    Please use plain text.
    *Expert Elite*
    Cadmanto
    Re: Exporting BOM Lists
    03-22-2012 05:01 AM in reply to: Anthony
    Anthony,
    You can RC on the BOM and select export.  Then under the file types there is a .txt file
    type.  These can be opened up directly inside of Word.
    Best Regards,
    Scott McFadden
    (2 Corinthians 5:21)
    Anthony
    03-22-2012 05:11 AM in reply to: Cadmanto
    Thanks yes I did see that option, it would be even better if there was a direct export to .doc option instead of this so that when the .txt file appears in Word there is no need to 'customize' the data to view correctly in Word. Maybe one for Autodesk to think about in the next release.
    *Expert Elite*
    PaulMunford
    03-22-2012 06:36 AM in reply to: Anthony
    You can't do it directly, but the option is available 'Under the hood':
    Check out this example from Brian Eakins:
    http://modthemachine.typepad.com/my_weblog/2010/02/parts-list-with-thumbnail-image.html
    The CAD Setter Out Blog
    @CadSetterOut
    Please use the Mark Solutions! Accept as Solution or Give Kudos! Kudos functions - Thank you!
    *Expert Elite*
    Cadmanto
    03-22-2012 12:43 PM in reply to: Anthony
    At least there is an option.  Might be your only one.
    Best Regards,
    Scott McFadden
    Anthony
    03-23-2012 04:20 AM in reply to: PaulMunford
    I have another question: I have renamed some parts in the BOM list so as to enabel them to be grouped, the problem is I loose the thumbnial when doing this, can you advise on how to retain the thumbnail when renaming and grouping parts ?
    *Expert Elite*
    PaulMunford
    03-23-2012 03:12 PM in reply to: Anthony
    That makes sense to me. The Thumbnail comes from the part file. If you roll up two or more parts, how will Inventor know which one to take the Thumbnail from?!
    @CadSetterOut
    Anthony
    03-26-2012 12:33 AM in reply to: PaulMunford
    I am grouping exactly the same part so Inventor should retain the thumbnail image as it's the same part !
    tech
    12-11-2012 10:01 PM in reply to: Anthony
    Hi have a look at BOM Tools. I think it can do what you need.
    http://www.mgfx.co.za/tools-for-inventor.htm
