• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    Accepted Solution
    Export to DWG, mising "Part Number" text parameter
    105 Views, 2 Replies
    12-03-2012 01:26 PM
    I'm using the "Part Number" parameter inside a block of text in my drawing, but when I export it to AutoCAD DXF 2010 format, the text in the exported file shows up as "<PART NUMBER>", instead of displaying the actual part number.
    -Autodesk Inventor Professional 2012
    Please use plain text.
    rhasell
    Re: Export to DWG, mising "Part Number" text parameter
    12-03-2012 03:49 PM in reply to: nannerdw
    I had the same issue a while back.
    Mine was via Leader text, t was also related to "Replace model References", it would only hapen after using that tool.
    The solution was to discconnect the leader and then re-connect the leader, before exporting the file.  I never did find a solution to the problem, it just went away with version updates and patches.
    Regards
    Reg
    Autodesk Product Design Suite Premium 2013 sp1.1 (1)
    Intel Core i7 (950@3.07GHz)
    Windows 7x64 (Home)
    12GB Ram
    Nvidia GeForce GTX 560 Ti (1Gig - Ver:314.07)
    Valued Contributor
    12-04-2012 03:56 AM in reply to: rhasell
    The text was attached to a leader, and disconnecting / reconnecting the leader fixed the problem.  Thanks.
