• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    WernerBeek
    Export text parameters of assembly into ipt (drawing)
    207 Views, 4 Replies
    10-05-2012 05:35 AM
    Deal All,
    I have created an assembly containing several parts. I want to export several  text parameters of the assembly and parts into the iproperties of the corresponding idw so that I can use them in a text block. Does anyone know how to makes this possible?
    Thanking you in advance,
    Werner
    Please use plain text.
    mrattray
    Re: Export text parameters of assembly into ipt (drawing)
    10-05-2012 05:53 AM in reply to: WernerBeek
    What version? I'll assume 2013.
    In a text note or in the title block?
    If you need it in the titleblock you'll have to use an iLogic script to do this. (A very very simple one)
    If you need it in a text note you can reference parameters directly in the text editor.
    Mike (not Matt) Rattray
    WernerBeek
    10-05-2012 06:00 AM in reply to: mrattray
    Dear Mike,
    Thank you for your reply. I am working with inventor 2012.
    This is exactly what I want, use the parameter into a text box. I do not know how to link the text parameter of an assembly or part with the ipt. Hope you can help me. With your solution you can not choose text paremeters.
    mrattray
    10-05-2012 06:24 AM in reply to: WernerBeek
    I belive linking text parameters in a drawing file is a new feature of 2013.
    Unless you want to upgrade, you'll have to use iLogic to filter through an iPoperty. Here's a snippet that will do so. You'll then simply insert the iProperty from the drawing into your text note.
    iProperties.Value("Custom", "PropertyName") = Parameter("yourPart.ipt.yourParameter")
     Edit: This is a great example of why you should always include your version of Inventor with your original question.
    WernerBeek
    10-05-2012 06:32 AM in reply to: mrattray
    Thanks a lot, that was the solution that I was looking for.
