I want to save a bunch of inventor 2009 idw's to AutoCad dwg's
I realise there are add-ins available for doing this, however i wanted to see how Task Scheduler performed this.
I chose a export files task then selected the idw's to save as dwg's
This all went well until i looked at the result.
two things the dwg is saved as filename.idw.dwg I do not want or need the .idw in the new file name, but can find no setting to remove this.
The dwg's are saved to a zip file Again i neither need or want these in a zip file I just want them save in the same folder as the idw
Anyone know if this can be done in Task Scheduler?
Inventor 2009
Hi swordmaster,
If you look in the Create Task list, do you see a Convert IDW to DWG task? If so give that a try and I think you'll find that it solves both the naming and the zip file issue.
Edit: Nevermind, Convert IDW to DWG is used for creating Inventor DWGs, rather than AutoCAD DWG's
I hope this helps.
Curtis
Hi
I can help with 2012, hope this is the same for 2009?
This is a three stage process.
1: This step only happens first time.
From Inventor, export a IDW to DWG
-Save type = AutoCAD DWG.
- Click Options
- Setup your prefered Configuration.
- Choose an AutoCAD template if required (Customised Layer config etc)
- SAVE the Configuration
2: Open Task Scheduler.
- New Task - "EXPORT Files"
- Select your files to be exported. (You might need to change the file filter/type to IDW/DWG)
- Click on one of the files. (The Options Button will become available.)
- Click Options
- Choose the Configuration file that you saved in the previous step.
- Set time to Immediately.
Done.
3: Use a file manager, something other than the POS call Explorer (I use Total Commander)
- Bulk rename all files to your desired name. (Even DOS is better than Explorer.)
- E.G. *.IDW.DWG to *.DWG
Time taken is a few minutes.
The more time consuming process is cleaning the files in AutoCAD, eg, deleting all the bits outside the drawing area. (The bits you don't want the client to see.)
Hope this helps, esp if it works in 2009.
The process set out by rhaselll will work in 2009, these are the same steps we used since Inventor 2008 to export to dwg.
Regards
Martin
If you go back into Inventor and set up another configuration on the first page, at the bottom, is a check box called Pack and Go. Uncheck this box and save the configuration and it will stop putting the dwg files in zip files.
Regards
Martin
Hi Martin,
Thanks for the tip on using Total Commander for the renaming of the files. I am aware of this software it is a great tool for doing bulk renaming. However it does have some disadvantages for me
1) This is licensed software and as such i would need to get my employer to purchase it
2) it add a step to the process which i was hoping not to do
As for the saving to a zip file, my dwg configuration file does not have the pack and go option checked, but still it creates the zip file.
Odd, It is definitely the check box that causes this. I have attached the .ini file (in a zip file as it seems .ini is not allowed) that I use to export to CAD, if you want to try it.
Regards
Martin
Looks like my dwg configuration file had become corrupted. I created it again and now it works.
thanks
In the reply Robert McMillan gave in : forums.autodesk.com/t5/Autodesk-Inventor/Task-Scheduler-export-idw-to-dwg/m-p/2652192#M369869
He told it is a defect.
Any change that is will be fixed in the new release?
