What I have is an External iLogic rule named "ExportDXF" that I would like to execute from a Macro. I would like to do this so that I can put it into a button on the quick access bar.
Thanks in advance.
Chris
Solved by MjDeck. Go to Solution.
I found this code in the forums, but haven't been able to get it to work. Could anyone tell me where I am going wrong?
Thanks in advance,
Chris
Sub RuniLogicRule() Dim iLogicAuto As Object Set iLogicAuto = GetiLogicAddin(ThisApplication) If (iLogicAuto Is Nothing) Then Exit Sub Dim doc As Document Set doc = ThisApplication.ActiveDocument Dim ruleName As String ruleName = "ExportDXF" Dim rule As Object Set rule = iLogicAuto.GetRule(doc, "ExportDXF") If (rule Is Nothing) Then Call MsgBox("No rule named " & ruleName & " was found in the document.") Exit Sub End If Dim i As Integer i = iLogicAuto.RunRuleDirect(rule) End Sub Function GetiLogicAddin(oApplication As Inventor.Application) As Object Set addIns = oApplication.ApplicationAddIns Dim addIn As ApplicationAddIn On Error GoTo NotFound Set addIn = oApplication.ApplicationAddIns.ItemById("{3bdd8d79?-2179-4b11-8a5a-257b1c0263ac}") If (addIn Is Nothing) Then Exit Function addIn.Activate Set GetiLogicAddin = addIn.Automation Exit Function NotFound: End Function
I am trying to run an external iLogic rule, however I put the rule in a drawing template file as well as in Inventor. No luck either way.
Instead of running iLogic, you can probably do everything in VBA. It should be easy to convert your iLogic rule to VBA. Can you post your ExportDXF rule? It might be based on the PublishDXF example from the Inventor API help.
That would be awesome if I could do that. I tried and tried to get the iLogic code changed to work within VBA, but couldn't get it to. So, I decided to try and got his route instead. If you could help get this tranlsated to VBA that would be great. I have 2 different codes. The first is to DXF out the file and the second is to PDF out the file. Each one goes to a specific folder on our server.
Thanks in advance,
Chris
' Get the DXF translator Add-In. Dim DXFAddIn As TranslatorAddIn DXFAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}") 'Set a reference to the active document (the document to be published). Dim oDocument As Document oDocument = ThisApplication.ActiveDocument Dim oContext As TranslationContext oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism ' Create a NameValueMap object Dim oOptions As NameValueMap oOptions = ThisApplication.TransientObjects.CreateNameValueMap ' Create a DataMedium object Dim oDataMedium As DataMedium oDataMedium = ThisApplication.TransientObjects.CreateDataMedium ' Sets directory for file save Dim DXFDirectory As String DXFDirectory = "\\ServerName\Shared\DXF Folder\" ' Sets save name as iProperties value Dim SaveName As String SaveName = iProperties.Value("Project", "Part Number") If Len(Dir(DXFDirectory, vbDirectory)) = 0 Then MkDir (DXFDirectory) End If ' Check whether the translator has 'SaveCopyAs' options If DXFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then Dim strIniFile As String strIniFile = "\\HMI-ENGINEERING\Inventor_Data\Miscellaneous\dxf.ini" ' Create the name-value that specifies the ini file to use. oOptions.Value("Export_Acad_IniFile") = strIniFile End If 'Set the destination file name oDataMedium.FileName = ThisDoc.PathAndFileName(False) oDataMedium.FileName = DXFDirectory & SaveName & ".dxf" 'Publish document. DXFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium) 'Launch the dxf file in whatever application Windows is set to open this document type with i = MessageBox.Show("Preview the DXF file?", "DXF Preview",MessageBoxButtons.YesNo,MessageBoxIcon.Question) If i = vbYes Then ThisDoc.Launch(oDataMedium.FileName)
path_and_name = ThisDoc.PathAndFileName(False) ' without extension PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}") oDocument = ThisApplication.ActiveDocument oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism oOptions = ThisApplication.TransientObjects.CreateNameValueMap oDataMedium = ThisApplication.TransientObjects.CreateDataMedium If PDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then oOptions.Value("All_Color_AS_Black") = 1 oOptions.Value("Remove_Line_Weights") = 1 oOptions.Value("Vector_Resolution") = 400 oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets ' oOptions.Value("Custom_Begin_Sheet") = 2 ' oOptions.Value("Custom_End_Sheet") = 4 End If ' Sets GetSetting strings Dim GetCustomer As String GetCustomer = GetSetting("Inventor PDF Location", "PDFLocation", "Customer", "") Dim GetSubFolder As String GetSubFolder = GetSetting("Inventor PDF Location", "PDFLocation", "SubFolder", "") ' Sets directory for file save Dim PDFDirectory As String PDFDirectory = "\\ServerName\E\PRINTS\" & GetCustomer & "\" & GetSubFolder & "\" & "PDF Prints\" ' Sets save name as iProperties value Dim SaveName As String SaveName = iProperties.Value("Project", "Part Number") If Len(Dir(PDFDirectory, vbDirectory)) = 0 Then MkDir (PDFDirectory) End If 'Set the destination file name oDataMedium.FileName = PDFDirectory & SaveName & ".pdf" 'Publish document PDFAddIn.SaveCopyAs(oDocument, oContext, oOptions,oDataMedium) 'Launch the dxf file in whatever application Windows is set to open this document type with i = MessageBox.Show("Preview the PDF file?", "PDF Preview",MessageBoxButtons.YesNo,MessageBoxIcon.Question) If i = vbYes Then ThisDoc.Launch(oDataMedium.FileName)
Here is the VBA version. Some things are a bit harder to do in VBA, and I'm not an expert. But this should work:
Private Declare Function ShellExecute Lib "shell32.dll" Alias "ShellExecuteA" _ (ByVal hwnd As Long, ByVal lpOperation As String, _ ByVal lpFile As String, ByVal lpParameters As String, _ ByVal lpDirectory As String, ByVal nShowCmd As Long) As Long Sub ExportDXF() ' Get the DXF translator Add-In. Dim DXFAddIn As TranslatorAddIn Set DXFAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}") 'Set a reference to the active document (the document to be published). Dim oDocument As Document Set oDocument = ThisApplication.ActiveDocument Dim oContext As TranslationContext Set oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism ' Create a NameValueMap object Dim oOptions As NameValueMap Set oOptions = ThisApplication.TransientObjects.CreateNameValueMap ' Create a DataMedium object Dim oDataMedium As DataMedium Set oDataMedium = ThisApplication.TransientObjects.CreateDataMedium ' Sets directory for file save Dim DXFDirectory As String DXFDirectory = "\\ServerName\Shared\DXF Folder\" ' Sets save name as iProperties value Dim SaveName As String 'SaveName = iProperties.Value("Project", "Part Number") SaveName = oDocument.PropertySets("Design Tracking Properties").Item("Part Number").Value If Len(Dir(DXFDirectory, vbDirectory)) = 0 Then MkDir (DXFDirectory) End If ' Check whether the translator has 'SaveCopyAs' options If DXFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then Dim strIniFile As String strIniFile = "\\HMI-ENGINEERING\Inventor_Data\Miscellaneous\dxf.ini" ' Create the name-value that specifies the ini file to use. oOptions.Value("Export_Acad_IniFile") = strIniFile End If 'Set the destination file name oDataMedium.fileName = DXFDirectory & SaveName & ".dxf" 'Publish document. Call DXFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium) 'Launch the dxf file in whatever application Windows is set to open this document type with i = MsgBox("Preview the DXF file?", vbYesNo, "DXF Preview") If i = vbYes Then Call LaunchFile(oDataMedium.fileName) End Sub Sub ExportPDF() Set PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}") Dim oDocument As Document Set oDocument = ThisApplication.ActiveDocument Set oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism Set oOptions = ThisApplication.TransientObjects.CreateNameValueMap Set oDataMedium = ThisApplication.TransientObjects.CreateDataMedium If PDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then oOptions.Value("All_Color_AS_Black") = 1 oOptions.Value("Remove_Line_Weights") = 1 oOptions.Value("Vector_Resolution") = 400 oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets ' oOptions.Value("Custom_Begin_Sheet") = 2 ' oOptions.Value("Custom_End_Sheet") = 4 End If ' Sets GetSetting strings Dim GetCustomer As String GetCustomer = GetSetting("Inventor PDF Location", "PDFLocation", "Customer", "") Dim GetSubFolder As String GetSubFolder = GetSetting("Inventor PDF Location", "PDFLocation", "SubFolder", "") ' Sets directory for file save Dim PDFDirectory As String PDFDirectory = "\\ServerName\E\PRINTS\" & GetCustomer & "\" & GetSubFolder & "\" & "PDF Prints\" ' Sets save name as iProperties value Dim SaveName As String SaveName = oDocument.PropertySets("Design Tracking Properties").Item("Part Number").Value Dim dirCreateOk As Boolean dirCreateOk = CreateFolder(PDFDirectory) If (Not dirCreateOk) Then MsgBox ("Could not create the directory:" & vbCrLf & PDFDirectory) Return End If 'Set the destination file name oDataMedium.fileName = PDFDirectory & SaveName & ".pdf" 'Publish document Call PDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium) 'Launch the dxf file in whatever application Windows is set to open this document type with i = MsgBox("Preview the PDF file?", vbYesNo, "PDF Preview") If i = vbYes Then Call LaunchFile(oDataMedium.fileName) End Sub Public Sub LaunchFile(pathName As String) Dim dirName As String dirName = pathName Dim fileName As String fileName = pathName Dim i As Long For i = Len(pathName) To 1 Step -1 If (Mid(pathName, i, 1) = "\") Then dirName = Left(pathName, i - 1) fileName = Right(pathName, Len(pathName) - i) Exit For End If Next Dim ret As Long ret = ShellExecute(0, vbNullString, pathName, vbNullString, dirName, 1) Debug.Print ("return from ShellExecute = " & ret) End Sub ' From http://www.developerfusion.com/code/1867/creating-folders-using-recursion/ Public Function CreateFolder(destDir As String) As Boolean Dim i As Long Dim prevDir As String On Error Resume Next For i = Len(destDir) To 1 Step -1 If Mid(destDir, i, 1) = "\" Then prevDir = Left(destDir, i - 1) Exit For End If Next i If prevDir = "" Then CreateFolder = False Exit Function End If Debug.Print ("prevDir = " & prevDir) If Not Len(Dir(prevDir & "\", vbDirectory)) > 0 Then If Not CreateFolder(prevDir) Then CreateFolder = False Exit Function End If End If On Error GoTo errDirMake If Not Len(Dir(destDir, vbDirectory)) > 0 Then MkDir destDir End If CreateFolder = True Exit Function errDirMake: CreateFolder = False End Function
It errors out at the following lines:
Set DXFAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3?AC4-122E-11D5-8E91-0010B541CD80}")
And
Set PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6F?D96-2F4D-42CE-8BE0-8AEA580399E4}")
The Run-Time Error that comes up is "Method 'ItemById' of object 'ApplicationAddIns' failed.
This is the same spot that I kept having issues with. I could never get passed this spot. I am not sure if the Item ID is incorrect or???
Thanks for all your help so far.
For some reason, cut and paste from this forum will introduce ? characters in some text. You can see it in those lines that you posted. Please try the attached text file ExportDxfPdf.txt
I was wondering if anyone could help me with one last thing. I am trying to figure out how to get the DXF export code to do all sheets? It will only currently DXF out the selected sheet.
Chris
Public Sub LaunchMyRule1() '<--- This is what you would tie to a button in a toolbar.
RuniLogic "Rule1"
End Sub
Public Sub RuniLogic(ByVal RuleName As String)
Dim oDoc As Document
Set oDoc = ThisApplication.ActiveDocument
If oDoc Is Nothing Then
MsgBox "Missing Inventor Document"
Exit Sub
Dim rule As Object
Set rule = iLogicAuto.GetRule(oDoc, RuleName)
Dim i As Integer
End Sub
Dim addIns As ApplicationAddIns
'Find the add-in you are looking for
Set addIn = oApplication.ApplicationAddIns.ItemById("{3bdd8d79-2179-4b11-8a5a-257b1c0263ac}")
addIn.Activate
Exit Function
NotFound:
End Function
