Autodesk Inventor
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Excel parameters - disable parts
- Highlight
- Email to a Friend
Hi there,
I have linked my inventor drawing to excel to adjust some parameters. Is it also possible to have a enable/disable function in excel so a part in an assembly can be disabled at will?
Thanks in advance!
Re: Excel parameters - disable parts
- Highlight
- Email to a Friend
which version of Inventor do you use?
If you have ilogic on board you can solve it by using a specific value in your excel.
If value_x=1 then suppress feature y
You only need a trigger to give inventor the start sign.
Best Regards
Passi
- Highlight
- Email to a Friend
Thanks for the reply,
I use the lastest version, 2012 SP1, only i never worked with iparts.
I tried to 'add rule' and then inserted this
If value_x=0 Then suppress Component.IsActive("part") = True
But this generates errors (not english)
translated:
Error on Line 1: The name was not suppress declared.
Error on Line 1: Method arguments must be enclosed in brackets.
- Highlight
- Email to a Friend
I hope you don't insert the code example that way, it was only a text for describing what I mean and not a correct syntax ![]()
I thinked about it and i think, I'ts not possible to create it via ilogic, because in my opinion you have to create a single LOD for each variant. But I will think about it later on ![]()
So it's better to create it via VBA.
This is a example for Suppressing a part in an assembly, if you know the correct name and folder of the part you want to suppress: In this case it's the part "flange.ipt" in "c:\"
Public Sub Suppress()
Dim AssemblyDoc As AssemblyDocument
Set AssemblyDoc = ThisApplication.ActiveDocument
Dim AssemblyDef As AssemblyComponentDefinition
Set AssemblyDef = AssemblyDoc.ComponentDefinition
On Error GoTo Error1:
Dim SearchPart As Document
Set SearchPart = ThisApplication.Documents.ItemByName("C:\flange.ip t")
Dim SearchPartOccurrence As ComponentOccurrencesEnumerator
Set SearchPartOccurrence = AssemblyDef.Occurrences.AllReferencedOccurrences(S earchPart)
Dim OccurrenceOfSearchPart As ComponentOccurrence
For Each OccurrenceOfSearchPart In SearchPartOccurrence
OccurrenceOfSearchPart.Suppress True
Next
Error1:
End Sub
Then Inventor will create a LOD by it's own. But you have to execute the Macro to create the changes. Or you create a start for the macro by open the assembly doc.
