• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    Error when try to Athor a I part **** a custom member to the Content centre
    102 Views, 4 Replies
    12-20-2012 11:16 PM
    Hi All,
    we are getting an Error when try to Athor an I part **** a custom member to the Content centre. Im the administrator,  when I use my coleuges machine the Authoring go through, security settings, pc setting everything is the same, I use the local host content centre,
    any Idea why this error appears
    see attached
    Please use plain text.
    *Expert Elite*
    cbenner
    Re: Error when try to Athor a I part **** a custom member to the Content centre
    12-21-2012 04:59 AM in reply to: jacoj
    Are you using Vault?
    ChrisB
    Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
    Active Contributor
    01-01-2013 08:59 PM in reply to: cbenner
    sure we do you uses Vault,
    but if I go onto another machine, with exactly the same settings, and exactly the same rights, im allowed to do this,
    even If I try to use the local host content centre on the C drive.
    kind regards.
    *Expert Elite*
    cbenner
    01-02-2013 04:09 AM in reply to: jacoj
    Can you make certain that FG is loaded on the machine where it does not work?  Go to Tools\Add Ins and look to see if Frame Generator is loaded in the list as in the picture here:
    ChrisB
    Active Contributor
    01-02-2013 04:20 AM in reply to: jacoj
    hi,
    yes, it has been loaded, has checked this before as well, and its was loaded.
    the right rights has been activated in the projects, and are logged in as administrator
