• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    jd789
    Error in inventor undo folder, how can I solve this?
    1255 Views, 2 Replies
    08-08-2012 08:38 PM
    Buenas el error que tengo es este ¿cómo lo puedo solucioar?// Hello this is the error How can I solve this?
    Please use plain text.
    Valued Mentor
    mpatchus
    Re: Error in inventor undo folder, how can I solve this?
    08-09-2012 05:11 AM in reply to: jd789
    Go to your Inventor options and look at the file tab..
    Undo should read ...
    Mike Patchus
    Inventor 2012 SP1
    Vault Pro 2013
    *Pro
    jletcher
    08-09-2012 05:58 AM in reply to: jd789
    I make a folder under my C drive called inventor undo and I map to that. This way if the error comes up again I can go to that folder and delete everything and restart inventor. All it is telling you is there is no more space for the undo files to go..
    James Letcher
    2012 Factory Design Suite ( will not load 2013)
    What happen to my Inventor :-(
