• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    New Member
    Error exporting IDW to DWG
    31 Views, 4 Replies
    11-21-2002 01:55 AM
    When exporting IDWs to DWGs in IV6 SP1, I get "Error Saving DWG File - Make Sure AutoCAD is Running." I get this error whether AutoCAD is running or not. The DWG seems to save OK, but I'm tired of seeing this error. Anybody else see this?
    Please use plain text.
    *discussion.autodesk.com
    Re: Error exporting IDW to DWG
    11-26-2002 04:38 AM in reply to: cjmies
    We noticed this same error. It seems to appear only if you specify anything
    less than AutoCAD 2000 as the format. Our Router software currently requires
    Acad R14 so it looks like upgrading has just forced us to
    do more, as now I must open each AutoCAD file exported and save as to r14.
    You may note that yes, your FIRST sheet acad file is OK, but if you use
    multiple sheets, that is the only one that will be exported.
    Any AutoDESK people reading this, please feel free to verify and hopefully
    fix this issue. My employer
    currently has no plans to upgrade our Router software.
    "cjmies" wrote in message
    news:f1260b3.-1@WebX.maYIadrTaRb...
    else see this?
    Outgoing mail is certified Virus Free.
    Checked by AVG anti-virus system (http://www.grisoft.com).
    Version: 6.0.423 / Virus Database: 238 - Release Date: 11/25/2002
    *Keller, Kent
    Re:
    11-26-2002 05:22 AM in reply to: cjmies
    Could you please change your login name to something that doesn't contain Autodesk in it?
    Many of us have our readers highlight Autodesk posts, and it makes you appear to be from
    Autodesk.
    Kent
    Member of the Autodesk Discussion Forum Moderator Program
    "discussion.autodesk.com" wrote in message
    *Slob, Bob the
    Re:
    11-26-2002 10:32 PM in reply to: cjmies
    Kent, sorry about that. I did not realize when I added the news server to
    Outlook
    express that the default username it setup was the same as the news server
    name.
    It should be different now I hope, as I changed it to something else.
    Bob
    "Kent Keller" wrote in message
    news:A2B4374527C0DCA51AAD20DC957A1F87@in.WebX.maYIadrTaRb...
    Autodesk in it?
    appear to be from
    > Autodesk.
    > Kent
    *Keller, Kent
    Re:
    11-27-2002 12:46 AM in reply to: cjmies
    It is definitely different... Thanks I think
    Kent
    "Bob the Slob" wrote in message
    > Bob
