• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    Member
    Error 1920
    399 Views, 4 Replies
    12-14-2012 03:43 PM
    "Error 1920". "The Service failed to start. Verify that you have sufficient privileges to start system services." This always comes up everytime I try downloading Inventor 2013. I am also a student,so I get it for free. I have tried running it as an administrator, but it still doesn't work. I have already downloaded all the needed drivers. I am attaching a screen shot. Please help me with this. Thank you.
    Please use plain text.
    *Pro
    Re: Error 1920
    12-16-2012 05:32 PM in reply to: rsoni1997
    Let's be clear on terminology to start with-- it looks from your screenshot that you are installing Inventor 2013, not downloading it, correct?  Downloading is how the installer gets to your computer from Autodesk's website, installing is getting the software configured and ready to run on your computer.
    When you run the installer have you set your UAC to minimum and stopped your antivirus utility?  Do you have administrator privileges?
    Member
    Re: Error 1920
    12-17-2012 02:07 PM in reply to: sbixler
    It doesn't work
    Member
    Re: Error 1920
    12-17-2012 02:14 PM in reply to: rsoni1997
    Is there a way an expert could remotely look at the problem and fix it?
    The problem happens when I install the Inventor 2013. The problem only shows up when it's installing inventor.
    *Expert Elite*
    Curtis_Waguespack
    Re: Error 1920
    12-17-2012 03:16 PM in reply to: rsoni1997
    Hi rsoni1997,
    You might ask this question over here:
    http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
    Autodesk staff  actively monitor the Installation & Licensing forum, working with the existing community to answer your installation and licensing questions.
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
