• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Accepted Solution
    Equation curves
    190 Views, 3 Replies
    01-29-2013 10:18 AM
    Hi
    I found tutorial for symmetrical equation curve for NACA Airfouil in Inventor 2013. http://www.youtube.com/watch?v=zKSBe9hImTE
    I need to create assymentric airfoil. I am wondering if there is a possibility to put equation in Inventor which looks like the one I attached in doc file.
    If it is not possible that's OK as I can use coordinate generator in the internet and put coordinates into inventor so I can draw it but It would be nice to put set of the equations rather than manually put 100 points.
    I know that those equations are more complicated and I don't know how to start with them in Inventor
    Please use plain text.
    pcrawley
    Re: Equation curves
    01-29-2013 11:51 PM in reply to: PiotrekL1
    I'm not in front of Inventor right now, so can't check the syntax for the equation curve editor - but I would say "yes", this is possible.  For now, I'd just recommend inserting points from Excel.  Inventor will draw a spline through the imported points for you - it's like the poor-mans Equation curve editor!  Have a look at the expanded tool-tip for the format of the Excel sheet.  (It's on the Sketch > Insert panel.)
    Re: Equation curves
    01-30-2013 12:43 AM in reply to: pcrawley
    Hi
    I will follow your advise. I will generate coordinates in the NACA tool and put then through MS Excel into inventor
    Thank you very much
    Member
    hanson.alex
    Re: Equation curves
    05-13-2013 06:43 PM in reply to: PiotrekL1
    Been working on this to...
    My end goal is to have an assembly with n number of NACA 4 digit (and others) profiles. This will allow the user to quickly develop a surface model to export to a CFD program.
    Parameters to control (between each section):
    • Sweep
    • sweep
    • dihedral angle
    • span
    • twist
    Parameters to control (For each section):
    • NACA Type
    • NACA Parameters
    • Camber length
    Step 1: Developing NACA 4 digit profiles
    Approach 1: Sketch Equation Curve
    Following equitation on http://en.wikipedia.org/wiki/NACA_airfoil, I was successfully able to develop the mean camber line (with two different equation curves). While trying to add the equations for the top and bottom of the profile, I ran into many issues most of which resolved after time, although not all.
    Problem(s):
    1.  The parametric equations are not fixed in space (i.e.. you can drag them around) and I have not been able to successfully relate all 6 curves, trailing edge, and leading edge (approx. as a circle).
    2. The beginning of the forward curves approach div by zero and are as such not useful.
    3. Very cumbersome, extremely hard to use and error prone.
    Approach 2: Thickness Circles + mean camber line = Spline (kinda)
    Using my sucsessful mean camber line, I added 10 circles along the mean camber line and demendsioned their linear poisiton along the mean cambber line using the x_u parametric equations, and their heigth demension from the x-axis using the y_u parametric equations.
    Problem(s):
    1. After passing the max mean camber position, things started going badly. It turns out that inventor was not parsing the equations correctly. This could be a program or user error, the jury is out on that one. See post here: http://forums.autodesk.com/t5/Autodesk-Inventor/Demension-Copy-Parse-Error/m-p/3920847
    2. Cumbersome (seeing a trend here). While I could type all the equation in the tiny window and get it work corretly, I feel I have better things to do in my life, and there is probably a better approach.
    Propossed Approach 1: iRule/iLogic/API
    The title is garbled because I don't know enough about each of those, but my preliminary research shows this may be the correct approach. The plan is to create a set of point using the parametric equations to define a spline.
    If anyone has any questions/comments/advise please let me know.
