• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    *Pro
    jletcher
    Enough is Enough with the BUGS...........
    311 Views, 4 Replies
    10-12-2012 09:01 AM
    Autodesk we need hot fixes for Inventor 2012. This is just getting to stupid and I am tired of it. When I set my settings I want NO I need them to stay.
    When I set my drawing standards to show only active it needs to stay that way.
    It keeps changing back to local styles and now I just found out there are 75 drawings on the wrong standards because this option does not stay to active. And a worker at a client did not notice and screwed up because your bugs are not fixed and was picking the wrong dimension styles.
    Now who the heck is going to pay for all this re-work NOT you. But my client believes I should.
    You have to understand we need software that is working STOP with everything else and start to fix this crap.................
    :smileymad: :robotfrustrated: :smileyfrustrated: :robotmad:
    un-less you are Autodesk DON'T reply
    James Letcher
    2012 Factory Design Suite ( will not load 2013)
    What happen to my Inventor :-(
    Please use plain text.
    Distinguished Mentor
    ampster
    Re: Enough is Enough with the BUGS...........
    10-12-2012 09:18 AM in reply to: jletcher
    you still expect to contact or inform Autodesk thru this forum created for end users?
    strike 2013
    strike 2012
    you can always fall back to 2011!
    *Expert Elite*
    mrattray
    10-12-2012 09:25 AM in reply to: ampster
    *Expert Elite*
    10-12-2012 10:13 AM in reply to: ampster
    ampster wrote:
    strike 2013
    strike 2012
    I vote for drawing board.  Kind of hard to blame mistakes on the eraser.
    Employee
    10-12-2012 12:25 PM in reply to: jletcher
    Hi! I am still trying to understand this issue better. Could you provide steps to reproduce the behavior? I believe you must have seen something not working correctly. But, without steps to reproduce, it is very difficult to find out where the problem is and how to fix it.
    Thanks!
    Principal SQA Engineer, Inventor
    Manufacturing Group
    Autodesk, Inc.
