• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Accepted Solution
    'End if must be preceded by a matching if'
    218 Views, 9 Replies
    11-23-2012 12:41 AM
    Iv attached a picture to show the error & my rule text. I have created the Parameters etc. & the statement includes if & end if. Cheers,Capture.PNG
    Please use plain text.
    Valued Contributor
    Re: 'End if must be preceded by a matching if'
    11-23-2012 01:33 AM in reply to: shmartin89
    If Parameter("HEIGHT")=152.4
    Parameter("UC_PROFILE")="152.4"
    EndIf
    If you are finding usnderstanding ilogic difficult, have a go at the online tutorials.
    Wayne Helley
    Inventor 2013 Certified Professional
    Autodesk Inventor Professional 2011
    Windows 7 Enterprise, 64-bit
    Valued Contributor
    11-23-2012 03:48 AM in reply to: waynehelley
    ** Use "End IF', not "ENDIF"
    Pasting into IE erased the space.
    Wayne Helley
    11-23-2012 04:58 AM in reply to: waynehelley
    Cheers,
    My text in the 'UC_designation' Parameter contains 'x's. E.g - 152.x152x23
    Inventor recognises this as an equation, therefor the rule doesnt work. Is there any way around this without replacing the 'x's?
    Valued Contributor
    11-23-2012 05:09 AM in reply to: shmartin89
    when you created the "UC_PROFILE" Parameter, did you create it as a text parameter?
    If not, in the parameters dialogue, use the drop down in the bottom left which by default says "Add Numeric". Select "Add Text" instead.
    Wayne Helley
    11-23-2012 07:40 AM in reply to: waynehelley
    Cheers Wayne.
    This is the first time iv started using Rules. If you havent already guessed!
    Sandy
    11-23-2012 08:17 AM in reply to: shmartin89
    Do you know if there is a way in which rules can be run automatically? E.g Everytime the part is updated or saved rather then having to press iTrigger
    Cheers,
    11-23-2012 08:24 AM in reply to: shmartin89
    NVM. Iv added the rule into event triggers.
    Valued Contributor
    11-26-2012 12:20 AM in reply to: shmartin89
    I'm not that knowledgeable about triggers I'm afraid, as I have only really been creating rules which I need to run on command, but have a look at this...
    http://inventortrenches.blogspot.co.uk/2012/01/creating-basic-ilogic-rule-with-event.html
    Wayne Helley
    Valued Contributor
    11-26-2012 12:23 AM in reply to: waynehelley
    I just realised NVM stands for nevermind so mevermind my last post also!
    Wayne Helley
